Hey Folks Just a courious question. What size air line, 1/2, 3/8, What size Valves, 1/2, 3/8 , What air pressure do you run in your tank,
I run 1/2 line 1/2 valves up front 3/8 in rear. I usually have about 160-170 in my tank it's a 7gallon
1" lines, 2" valves, and 900psi with a 50gal tank. j/k. does a smaller line allow for smoother slower depression and airing up the bags?
yes Smaller line will make goin up slower. 3/8 valves are still fas dropping but you can run slow downs on them.
I've seen folks with 1/2 lines and 1/2 valves and when they drop they drop hard... my wifes Mazda has the valves in the rear, and 3/8 lines running to the front and it takes a second or two to get down.
Yes, I definitely have to be careful airing down, thinking about adding a set of flow controls. Also control for the rear fill, as the 1/2" lines and valves are fast.
Yah my truck drops like a rock. I'll def have to get some slowdown valves but for now I just gotta feather it lightly or im munchin gravel with my bumper cool thing though is I can hop the front off the ground kinda and inch or so at full pressure in tank
Yeah see thats what I'm expecting with mine when it's a rolling again is it's gonna drop like a rock.. The thing is if you add slow downs on your exit valves, then you can't bounce. I don't mean Hop but up down up down up down, to appear to bounce, the Mazda goes up perty quick but dropes slow..
I typically run 3/8" everything. Sometimes 1/4" in the back with a lever setup. And I always run a pipe plug in the dumps with an 1/8" or 3/16" hole drilled in it. I like being able to feather down and cruise 1/2" off the ground.
here i am about a inch off the ground an i have 3/8" valves 1/2" line an i run 150psi on 2 5 gallon tanks
