1974 - contemplating bagging
Discussion in 'Suspension/Chassis' started by digital-i, Jan 19, 2011.
  1. digital-i
    digital-i Member
    Hawaii
    1974 Hi-Lux
    so thinkin about about front bagging my 74 ... the question would be where and how to mount the shock on the front (even if i could find bags that would fit) any suggestions/opinions/do's and dont's (got pics ?) ..... rear would be air shocks with blocks
  2. TRUCK ACTION
  3. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    The front of those is similar to an S10, as far as looks. Bag goes in the spring pocket, and it needs to be cut for room. And the shock goes on the outside of the control arm, opposite your steering.
  4. Dogfather
    Dogfather Veteran
    Rochester, Washington
    Hey Bud, I have a 76 Almost Identical, with some minor differances. As I have been looking around the web I have saved the different site links so I can refer back to them.
    Here is a link to my reasearch thread with links to Burnya's, Twisted minis, a guy on the s10 forums who did an awsome build thread and the guy is a good Meatle worker too.
    Enjoy.
    Dog Pound Minis Toyota Research Thread
  5. digital-i
    digital-i Member
    Hawaii
    1974 Hi-Lux
    thanks for the advice guys (awesome thread on the S10), my guy here, at Forjworks, Forjworks.com is concerned that if i continue to run the stock rims (which i am pretty sure i am) it will hit the front shock with current offset , might be straight bagged no front shock.. just a little bit bouncy ? bad idea ? researching bags to drop in with current cups with out cutting.... hopefully the theory of the 83-97 Mighty Max thread by Seventy6Celica applies
  6. powertech
    powertech Enthusiast
    FL. Keys
    1970 hilux
    are there going to be any old mini trucks left that have not had there springs and driveabilty torched out and replaced with balloons and gizmo's. and transformed into some kind of homeboy pimp mobile a guy could hardly drive without blushing.
  7. yota4life
    It's not a "homeboy pimp mobile" it's a way to get lower with saving your back from not bein static an a sh*tty ride quality. An you have the choice of riden at different ride heights makes going in an out of driveways an over speed bumps so much easier. An there are still lots of trucks tht haven't been cut up not alot of ppl do this cause they can't afford/ no skills to do it. I don't blush every time I drive my truck. I get alot of complaments especially from the old guys.
  8. dillinja666
    go sh!t in another thread, you dont like bags dont comment
  9. Comrade_Charlie
    Comrade_Charlie Veteran
    Rock Hill, SC. Charlotte, NC
    1973 Hilux
    I am doing just a static drop as low as I want, it doesnt have the good drivablity as a bagged truck, its not my DD either, but im just doing that because im into fast cars and this truck is just a side project and im not dumping money into lowering it, i just have cut xterra springs and blocks. I have nothing against bagging, I just dont want them.
  10. digital-i
    digital-i Member
    Hawaii
    1974 Hi-Lux
    wow... to be honest i didnt expect that, everybody has got a right to there own opinion, I want to see my truck lowered.. and i need to adjust the height to make it in to the garage, so bags seem to be my best option, I am looking for bags to drop-in with no cutting., if theres none , it aint gonna happen.. so we will see
  11. Comrade_Charlie
    1973 Hilux
    Haha I need to make sure I dont lower mine so much I cant make it in my driveway, its gravel and pretty rough and somewhat steep for a lowered vehicle. Bags are awesome when you lay frame or whatever they call it. Always wanted a mazda on bags.
  12. burnzya
    honestly you're not gunna find a bag to fit the stock pocket without any cutting. even a re5 will need some trimming.
    even running hydraulics will require some cutting, and thats about as small of a diameter you can get.
  13. digital-i
    digital-i Member
    Hawaii
    1974 Hi-Lux
  14. dillinja666
    you cant run those in the front, the fronts need to have the traditional style cause of the swing of the control arms. Those bags need perfectly verticle travel or else they get all bound up and fold on themselves.
    i personally like slams cause they are so stiff. RE-7 Slam Specialties Air Bag 200psi Single 1/2" Port
    people have had problems with them as of latley cause of a bad batch or rubber, but the lifetime warranty and their badass customer service has kept me a returning customer for life
  15. digital-i
    digital-i Member
    Hawaii
    1974 Hi-Lux
    dillinja666> thanks for the info ! have u installed or seen installed ? pics ?
  16. burnzya
