Bagged guys
Discussion in 'Off Topic' started by yota4life, Jan 7, 2011.
  1. yota4life
    Alright so on my ford it takes alot to lift the front driver side bag. Like 120psi on driver side an I'd say 80ish for the passenger side. When I fill them both to 120 the passenger side gets way more lift. What could be causin this. Only thing I can think of is different sized bags on the front
  2. macawilial
    macawilial Veteran
    Born and raised in San Diego
    Sounds like 3 possibilities
    1. Could be a bad pressure sensor on one of the bags... driver OR pass side.
    2. Could be a bad shock/shock placement which is causing it to slow things down.
    3 Two diff. size bags upfront but I see no reason why this would have been done.
    Good luck
  3. yota4life
    Neither do I but why would someone use speaker wire to wire everything lol. I'll try unbolting the shock
  4. macawilial
    macawilial Veteran
    good idea
    to rule things out quickly, try swapping the pressure sensors around. If the reading follows then you know you have a bad sensor. If not, then you prob have a bad/stiff shock causing the problem
  5. macawilial
    macawilial Veteran
    Just thought of this...
    When was the last time you checked you're ball joints? Maybe they're dried up and full of friction?
  6. yota4life
    The gauges are just air line to a dual needle. Haven't checked the ball joints out yet. I'm thinkin it could be the shock i remembered it's at a pretty severe angle. And idk if the passenger side has a shock I'll have to check
  7. Litneon
    I have also seen one bag mounted slightly in or out from the center of the other side. This would create more leverage on one side requiring less pressure to lift. Also, the further out on the arm it's mounted, the less lift you get, even at full pressure. Make sure the lower bag plate is mounted using the same bolts/holes.
  8. yota4life
    I'll have to check it out in day light. The bags look like mounted in same place but I'm guessing it's the shock
  9. dillinja666
    its cause your fat ass is on the driver side :) :p:doah::nana::ROFL:
  10. layedout94
    layedout94 Enthusiast
    aberdeen
    94 toyota hilux
    Yea that **** is annoying my drivers side bleeds of slower then the passenger... when I go to pancake it looks retarded lol
  11. yota4life
    I can't be called a fat ass lol I'm only 155lbs
  12. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Sure you can if you're short.
  13. dillinja666
    hahahah
  14. yota4life
    I'm 6'3" lmao
  15. bodybagged
    bodybagged Enthusiast
    Mesa AZ
    toyota clipped datsun
    make sure the line from valves are equal to each other per side. also make sure there are no kinks in the line. other then that make sure bags are the same and either suspension parts are to tight on 1 side or to loose..
  16. yota4life
    Lines are equal length. It's not the shock I don't think both sides have them an passenger is fine. Still leaning towards different bag sizes or maybe even in different spots
  17. NotAvailable
    NotAvailable Addict
    its most likely a kinked line. somewhere its kinked pinched or something. its not ur valves. different heights could be caused by different bag bracket placement. or as u sed different bags. but if the bags was different u would tell drastically.
  18. yota4life
    But say I have 160 in each one side is still alot higher. Maybe it's bag placement as stated. I'll have to check when it's better weather
  19. Litneon
    It could also be a ball joint or something else binding. Did you say that the one side stays lower the whole way up?
  20. yota4life
    Ya no matter what one side is lower. It has dhm control arms on it idk what kind of bjs those use
