do you use synthetic
Discussion in 'Engine/Drivetrain' started by layedout94, Jan 5, 2011.
  1. layedout94
    layedout94 Enthusiast
    aberdeen
    94 toyota hilux
    Yup basically wat the thread is named
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    i did a long time ago, then just realized it is a waste of money, my engine is not high performance or anything and i dont think the minimal benefits is worth the money on my truck, regular ol valvoline 10w30 works just fine and is recommended by manufacturer
  3. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Wait for raf to respond, he had the answer to that, or was it another guy?
  4. IronNam
    I use Pennzoil Platinum 5W-30. Truck used to have Mobil 1 10W-30.
    I only used Pennzoil Platinum because its quality is higher.
    Personal Preference
  5. garagedoorman
    garagedoorman Addict
    north georgia
    Hmmmmmm........... Yes. I've found that since working with older cars, synthetic oils help maintain the engine with less wear and tear. Also goes for transmissions, rearends. Synthetic oils were originally made for aircraft jet engines because the oil handled extreme cold and heat better than mineral oil, and the ability to reduce friction.
  6. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    I use synthetics in most of my cars. In my 94 toy I def use it as it's just a baby with only 35,000 miles. From the point of view of cost....I have only put 2000 miles on it in the last 2 years. Changing oils once a year makes the cost really a moot point.
  7. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    I use synthetic oils in all my cars as well. They all get driven hard.
  8. Litneon
    Yeah, the cost difference argument doesn't work out. You can go three to five times as long between changes with the synthetics. Plus it protects better against thermal breakdown and cold starts.
    I use it in both vehicles now.
  9. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    I use full synthetic, i try to go with royal purple when its on sale if not its mobil 1 full synthetic 10w-30
    also mobil 1 has a oil thats supposed to help increase mpgs? imma try it out on my next oil change and see if it works.
  10. layedout94
    aberdeen
    94 toyota hilux
    Sweet thanks guys
  11. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Yep...I use Royal Purple in all my toys & in my girlfriend's car as well.
  12. IronNam
    I looked at a research and Royal Purple didn't do so well.. for its price. I'll find the link soon.
  13. 83SR5LB
    83SR5LB Member
    victorville, ca
    83 SR5 LB 2x
    Just got some mt-90 the other day, not in yet, hafta do the shifter seat and bushing. but syn is good without any oil leaks, but, if there are leaks it just rust proofs parts anyway lol.
    the syn idea is excellent in most apps.
    With a high quality big oil filter and syn, the oci is a long one and it stays clean with a high quality air filter.
    New fuel filter and pcv valve helps too. Tried a set of all Napa Gold filters and went 6k and the oil was still gold, I was amazed.
    This next oc I would like to test Castrol Edge 5-30, a Napa 1515 gold oil filter, and a Gold air.
  14. flg8r22
    flg8r22 Enthusiast
    Orlando Florida
    81 4x4, 83 4x4, 86 4x4
    we run amsoil synthetics in all of our company trucks. oil, rear end trans etc since new. they are all 2004 model chevy 2500hd. we change oil every 10k. lowest mileage truck has 308,000 miles and pulls as strong as it was when new. (and these are tow trucks) no failed engine or drivetrain parts :)
  15. IronNam
    some Chevys!
    My recent oil change was a 5k. 10k seems a lil sketchy.. lol
