z frame
Discussion in 'Suspension/Chassis' started by Lotoy, Jul 7, 2013.
  1. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    well got the trans member in and got the truck laid out. Totally forgot all about Z ing the frame. I fully expected it to lay all the way out:duh: well after reading some build threads looks like im Z ing the frame. any tips or suggestions would be great.Im defiantly body dropping it but I want it to lay flat before I cut it I want to keep as much head room as possible and a/c.
  2. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Theres a few threads on here tht talk about it. Search body drop? An I believe shadtree mechanic was the author an on page 5-9 he Zs his
  3. Adrian_0psi
    Adrian_0psi Newbie
    I have a ? Where or how would you mount the grounds and coil and fuse box sense everything is cut out I have a 93 bodied and I am stuck on the harness
  4. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    This thread is nearly 3 years old, so a new thread may be better for you. But, to answer your question, you mount it wherever you can fit it that looks not bad. Extend or shorten wires as necessary.
  5. Adrian_0psi
    Adrian_0psi Newbie
    Ok thanks
