my idle for my truck is around 800rpms... the truck will die unless i peddle the gas until the temp gauge moves a little bit...what could cause this..thanks
87 ...22r motor carb....and correct it runs solid once its warmed up....it also sounds like it has a miss on it...if i keep it at 3 grand it likes to pop...i was thinking the coil pack
yea i bieleve...i bought a rebuilt one from a friend..it looked just like the other one...how would i adjust the timing? my honda i just had to turn my distributor...im sure there is an easy way for yotas too
Check to make sure your choke is working too. If the choke is not closing it will create a lean run issue when cold and a lean engine will have a little miss as well. G
its probally the choke causing problems, my last 87 truck with a stock carb wouldnt run worth carp till it was warm, egr can cause similar problems as well after while i bought a weber carb and was happy
