Wilwood brakes
Discussion in 'Suspension/Chassis' started by Greenghost0101, Jul 8, 2013.
  1. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Yep.
    I run 16s with lots of clearance. 15s "should" clear.
  2. Greenghost0101
    Greenghost0101 Member
    Raffaelli what did you use? I will have a 15x3.5" wheel up front. Also if I use the top hat could I get a smaller rotor? Does anybody have adapter plates for the wilwood calipers?
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Wilwood dynalite calipers mount directly in place of 4x4 toyota from what I've seen.
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Every rotor has a different height, thus a offset @ the bracket for the calipers!
    Also different mounting hole sizes & pattern.
    I got my front brackets from a guy on this site,made for Toyota 4 Runner calipers to the Wilwood rotor set up!
    I had to make my own for the rear ,where I use a Ford rotor,different from the many for GM rotors!
    I doubt any large rotor will fit inside a 15'' rim!!!
    Do The Home Work---find out what works!!:cool:
  5. IronNam
    He used 1995 LS400 calipers and rotors.
    Top bolt of calipers lined up, bottom bolt hole needs to get redrilled 1/2-3/4" away.
    Rotors needed the center bore opened up a bit.
  6. Raffaelli
    Houston
    82 Longbed 2WD
    - Cutting, welding, fitting, machining, and cursing required.
    I don't see the point of you putting big brakes if your worried about using "runners." And besides that, im not gunna lie, they weigh a ton! (Just like a 2jz if that's what your swapping)
    A 4 inch wide tire can only grip so much. I would suggest using at least a 17x7 or bigger, but its your build. I understand some people go for a certain look.
    But Nam is right. Lexus rotor needs some grinding, then drill and bolt it to hub. Then machine true on a brake lathe. Caliper bracket needed a bit of grinding, welding and drill and tapping, but not complicated.
    IF I was to do it again, I would have used rotor and calipers from a 94-04 mustang cobra. 13 inch and looks like it would work fairly easily. But 17in wheel.
  7. Greenghost0101
    Well I talked to a shop were I live at and I'm gonna have them make a-arms and everything else I need to have a mustang II spindle, brakes and wheels. I'm gonna run the skinny wheel because I will be drag racing the truck!!:) I will start a build thread when I get back off vacation. Thanks everybody for the help I'm very excited about doing this build!
  8. sitnlow4life
    sitnlow4life Enthusiast
    Detroit
    92 Std Cab 2.4L
    I'm running SVO rotors in the rear with GM Monte Carlo calipers
    The brackets I bought are made for a 4x4 truck to be used with 6 lug GM rotors
    They don't completely engage the rotor
    What does your bracket look like ?
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Made these by hand,would have been nice to have had access to a mill!:cool:
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    The notch allows the caliper to center over the rotor!:cool:
  11. sitnlow4life
    Detroit
    92 Std Cab 2.4L
    I was just going to shorten the brackets I already have to accomplish the clamping of the whole rotor .
    It looks like the brackets you made are not offset like the ones I have
    Are they indeed straight ?
  12. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Correct!
    The offset does what I did by notching into the bracket!
    The brackets I've seen are all for GM calipers & rotors,the rotors are a different height than Fords. Thus a different offset!!:cool:
