Will these fit?
Discussion in 'Wheels/Tires' started by arl33323, Sep 12, 2012.
  1. arl33323
    arl33323 Enthusiast
    Norfolk, Va
    84 22r
  2. Minitoy
    Minitoy Enthusiast
    So cal
    89 xcab
    German wheels do not fit jdm or American cars.... I've try lol on my 240
  3. arl33323
    arl33323 Enthusiast
    Norfolk, Va
    84 22r
    Well dang. Oh well on to the next idea thanks.
  4. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Here try this. There are many other sites that do the same thing but I use this one the most since it also gives hub bore which is important because it the hub bore isnt big enough it will not fit over the dust caps.
    Cheap Custom Rims - Vehicle Bolt Pattern Guide
  5. arl33323
    arl33323 Enthusiast
    Norfolk, Va
    84 22r
    If all the info listed for 92 is the same for the 84 then cool that's some good info to have.
    also since I want factory rims can I plug in the year and stuff for the car I wanna take rims from and just make sure it matches my vehicle? Sorry if it's a stupid question but I just wanna make sure b4 I go out and spend money.
    Oh yea is there anything in particular I should look for when I'm buying used rims? I know the usuals like bends warping and just general make sure their round.
    Thanks
  6. pig rig
    pig rig Enthusiast
    bow washington
    make sure the center bore is big enough for the front hub
    real quick I help your search a little easier most GM wheels wont fit. ford and dodge cars will your looking for a 5 on 4 1/2 or a 114.3 pattron
  7. eurofreak2002
    B-town 208
    Yah your lug pattern and bore are same from 84-94 I forgot that site didnt go back to older things.
    Pattern 5x4.5 AKA 5x114.3, center bore is 67mm most truck rims come in a 73-76mm bore so getting hubcentric rings wouldnt be a bad idea but if your just cruising the streets and not going offroad or racing then usually can get away with not using hubcentric rings.
    Due to numerous offset and backspacing situations you will find TONS of rims that will fit bolt pattern and hub bore but might need spacers...For instance Nissan 350Z rims fit but you will need spacers for front so the rims sticks out a bit and the center cap clears the dust cap on the toyota.
    Toyota trucks have a low to medium offset so like 0-25 is good, you can get away with larger offsets like 35-42 but there might be some rubbin issues in the front. For instance the rims I have on my truck at the moment are a +42 offset so the fronts kinda sink into the truck and I have rubbing issues at full lock steering especially when riding really low.
  8. arl33323
    arl33323 Enthusiast
    Norfolk, Va
    84 22r
    Ok so from the site you gave me the specs from the Benz are 5x4.41, 5x112, 24 to 43, 66.6 and 66.6. So I'm assuming that they may work. I'm I right? If not does anyone know of some rims that would work and are similar to those? I'm basically looking for something similar to these or look the ones off an escalade. I like the dish look
  9. Sr.Solrac
    Sr.Solrac Member
    try looking at some chrysler rims if your looking for a similar style?
  10. arl33323
    arl33323 Enthusiast
    Norfolk, Va
    84 22r
    Cool thanks
  11. 85pickamatruck
    85pickamatruck Veteran
    Seattle
    85' Base
