If I'm planning to go lower on the front, so far I have DJM LCA, BJ Flip. If I were to add Belltech Drop Spindles would it give me a lot of problems?
I have beltech spindles and the problem with um is that if u don't got the right offset you'll be eating the in side of ur rim and u can't turn full or it'll touch the bars running from the front end to the lca. That's my issue with um but if you got the right off set you should be fine
