where is the best place to buy air ride fittings?
Discussion in 'Frequently Asked Questions' started by krazedprof, Feb 26, 2012.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    i am looking for new fittings as im upgrading to all 1/2 inch and sd is out of stock and is push connect better than compression or the same
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I run 3/8'' all push to connect Parker fittings,no problems !
    I 've brought from all the main sources!:cool:
  3. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
  4. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I like ptc for easy installation an never had a problem with them
  5. krazedprof
    krazedprof Addict
    iowa
    thanks for all the recommendations guys im gonna order from these guys Illusive Design & Fabrications as i ordered my tank from them and seem to be pretty good
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I never heard of this site.
    They look alright ,though I don't see that they have a DOT approval!:cool:
  7. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
  8. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Did you get PTC or nickel plated?? The price you said on FB seemed high! I know I spent $90 on all mine but I got 14 fittings and the 4 for airilines out of tank and the 2 for my leader hoses are nickel plated
  9. krazedprof
    krazedprof Addict
    iowa
    there ptc but 4 of them are the ones that are 1/2 x 1/2 x1/8 for the gauges since im running a line from each bag and i believe those alone were 12 something a piece. and the others are nickel plated.
  10. macawilial
    macawilial Veteran
    Born and raised in San Diego
    just my opinion
    PTC works great for 3/8" lines but if you're running 1/2" lines, you should go with compression fittings. Do it right the first time and you'll save all the air leak headaches
  11. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    Ya I'm a little scared about running PTC on 1/2" lines. I usually run compression on 1/2" as well
  12. eurofreak2002
    B-town 208
    IDK my 1/2 comp fittings leak like a beoch and Ive re-taped them 2x and replaced the ferrals 2x still leak a bit. HOWEVER I run 200psi so im sure PTC would do me NO good.
  13. dillinja666
    Have you tried the parker line with their barb fittings? I loved those and had no leaks with 200+ psi on my fullsize. I had leaks from my valves, not from any of my fittings...amazing stuff but super $$$$
    side note: DO NOT MIS CUT YOUR HOSE AND INSTALL YOUR BARB FITTING WITH PARKER, YOU WILL NEVER EVER GET THAT BITCH OUTTA THERE.
  14. krazedprof
    krazedprof Addict
    iowa
    i use to run 1/2 ptc on my 79 chevy and never had them leak im mainly upgrading to 1/2 inch for the v8 in the front so it will raise faster and i might put my 3/8 back on the back not sure till i get it all installed im not gonna run nitrogen or anything prob only run about 150-175 psi
  15. krazedprof
    krazedprof Addict
    iowa
    so the fittings i ordered are gonna be my spare/ backups since im now going to run 1/2 parker compression fittings
