Hey guys I was just wondering if anyone had replaced the switch for headlights and if so how easy it is
I've done mine because it was faulty and I found it fairly easy. After removing the column covers and steering wheel, unscrew the headlight combo switch. Trace the wiring to the harness under the dash and use a jewelers screwdriver to lift the plastic tabs which hold the wires into the connector. Kind of hard to describe, but I hope this helps. Write back if you need more directions. Rick
Like he said, column covers a steering wheel, then a few screws to take the switch assembly off. Hope you get it sorted out.
