Vibration that doesn't feel like its the tires! WTF
Discussion in 'Maintenance/Repair' started by joeynational, Aug 22, 2012.
  1. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    My truck has recently developed a vibration like i've never felt before. It vibrates the whole truck but to me seems to be coming from the drivetrain. The steering wheel doesnt shake like an unbalanced tire or alignment, in fact it doesnt shake at all. It also feels like its robbing power. I 've crawled underneath and the drive shaft is plenty tight, hardly any play at all on both ends. My front suspension needs all new parts (ball joints, tie rod ends etc etc) but it doesnt feel like its coming from the front..anyone have any ideas?
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Does your driveshaft hit your cross brace on large bumps ? What speed does it start at
  3. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Sounds like maybe the pinion angle is out. It could cause u-joint wear and the cause vibration and or caust the driveshaft to fall... I would check this soon. A drive shaft falling out can be deadly to you and your mini...
  4. IronNam
    Check motor and transmission mounts! Keep looking, inspect it all. Good luck, be safe bud!
  5. Beefed Taco
    Beefed Taco Addict
    Check out this thread. This guy got a vibe when he swapped trannies and did his clutch. It ended up being the trans he swapped in. This may not be your issue but it's just one more thing that can cause vibes.
    Driveline vibrations - CustomTacos.com Forum
  6. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    caliper
    When you said robbing power I was thinking your caliper might be getting stuck.But then again it wouldn't be happening all the time. It would only start binding when it was getting super hot already. Just something to check.
  7. IronNam
    He'd feel it in his steering wheel if it was brakes.
    I'd say get it on a lift and inspect the frame. Then every suspension component. With the rear tires up, does the axle rotate freely?
    Good luck man.
    and hopefully everything is holding together! :O
  8. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    sounds like a drive shaft problem:D
  9. Gman
    Gman Member
    Nor-Nev
    78 pickup
    I'm also thinking that...
    joeynational
    , Do you feel the vibration more through your shifter or your seat?
  10. joeynational
    PHX,AZ
    91 2WD
    I feel it in the shifter...
    From what I can tell all motor mounts are good, it starts about 20mph and kind of goes throughout the speed range from there. I haven't done anything to pinion angles or dropped the truck anymore. it just started all of a sudden..Haven't had time to get it off the ground, but i did see that episode of mythbusters with the broken drive shaft:eek: lol, gotta fix it fast!!
  11. joeynational
    PHX,AZ
    91 2WD
    no it doesn't hit anything
  12. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    In the shifter u feel it ..maybe unbalanced flywheel or clutch assembly or a worn out transmission input shaft again just throwing thouths out there seems to be a few guys on here with mysterious vibrations
  13. joeynational
    PHX,AZ
    91 2WD
    ^^ yeah I feel it in the shifter/tranny area..I'm doing a full front suspension rebuild so at that time I may drop the tranny and inspect clutch/flywheel
  14. Malessohomegrown
    Malesso,Guam
    Hey Joey I recently had a vibration thru my shifter. After changing my trans then con rod,thrust and main bearings I pulled of the clutch and found my flywheel bolts had run loose and I always lock tight them. I torqued them back down and felt stupid because that's what I first suspected.
  15. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    The pilet bearing might be going out
  16. joeynational
    PHX,AZ
    91 2WD
    Thanks, i'm going to drop the tranny when i get a chance, i feel like its in the same area as well
    I hope not! Its only a year old!
  17. IronNam
    Open road.
    Go above 20mph.
    Clutch in, neutral.
    Does vibration seem any different?
    Check / Inspect:
    Transmission mount.
    Driveshaft for missing weights.
    Driveshaft for missing bolts.
    That's as much as I can think of.
  18. 22r
    22r Veteran
    Maui
    you can try tighten the 4 bolts that hold the driveshaft on the pinion flange in a criss cross pattern. i had the same vibration problem before, i had one of the four bolts that were supposed to be on.
  19. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Like Cin asked, does it change in neutral, how about engine braking?
    Check your transmission and diff fluid level. Could the trans or rear end going out.
    if the clutch is out, it won't be the pilot bearing because the engine and input shaft are spinning together then.:brickknock:
  20. kingtacoma951
    kingtacoma951 Addict
    CORONA,CALI
    88 SR5 Xtra Cab
    so whats been goin on joey?? im having the same problem but i feel the vibration all over the truck not bad tho just noticed it...any answers would be great :) and my speedometer MPH isnt working...prolly my tranny:(
