Truck is leaning on one side
Discussion in 'Suspension/Chassis' started by Christopher Sutton, Aug 18, 2016.
Tags:
  1. Christopher Sutton
    Christopher Sutton Member
    Rocky Mount, NC
    85 Pickup 2wd
    Hey guys, so I just threw some 3 in blocks on the yota. The truck is leaning on one side. The driver side some edge of fender to the rim is 5 1/4 inches. The passenger side is 4 3/4 from fender to rim. The truck always seemed to be leaning but I can definetley tell now with the smaller wheel gap. It levels out once I sit in it though. Haha
  2. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    yep, toyota lean. adjust your torsions to compensate....or just set it more. lol
  3. Christopher Sutton
    Rocky Mount, NC
    85 Pickup 2wd
    Yeah but I'm having the lean on the rear. Not the front.
  4. jetas
    Adjusting the front will help.
    You can always try to get a bolt on block from beefedtaco but id say adjust the torsions
  5. Christopher Sutton
    Rocky Mount, NC
    85 Pickup 2wd
    Alright. I guess I'll give that a whirl next when I get some time. Thanks guys
  6. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    get your truck on a level surface and measure all 4 corners...see where its off. if one side of the front is off it will make the opposite corner rear off. which you can tweak with a torsion bar adjustment.
  7. Christopher Sutton
    Rocky Mount, NC
    85 Pickup 2wd
    Update: Drove a 100 some miles and retorqued the u bolts. Upon crawling underneath I noticed that it's level. I guess it had to settle in.
