Clean the throttle body and mess up the TPS.First one I got from autozone. Could not adjust it to the specs. Return it. Got one from 1sttoyotaparts which looks identical. Still could not adjust to specs. Check with other pickup and readings are closer to specs. Could the throttle body be bad or am I missing something else? Trucks runs good and pass smog, but the tech said things are a little off. So I told him I put in a new TPS. He said to get it TPS set correctly. Should I just leave it? Haynes says .57mm IDL-E2 less than 2.3k ohms .85mm IDL-E2 infinity
