Torsion problem
Discussion in 'Maintenance/Repair' started by Noahj_95, Apr 20, 2011.
  1. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    Need help to raise my truck up? I think my torsion bars r broken our frozen cuz wen i twist the torsions the front dosent go up it still stays same hight. And my truck is lower in the front then the back?
  2. Zombie Monarch
    Zombie Monarch Veteran
    Springfield, MO
    1991 single cab dually hilux
    Are you jacking up the front when you do this? If not give it a try.. I've never done torsion bars but I've read a little about them
  3. jetas
    Put the front end on jackstands. And are u holding the nuts while turning the bolt?
  4. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    Me n my fren jacked it up n we twisted the torsion but the front didnt come higher it jus stayed same hight so we took it of the jack n tryed it but it still is the same hight? Do you guys think my torsion is broken from being that low for to long.
  5. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    ^____ What he said. You can't just turn the bolt, you have to "hold the nuts" :p
  6. jetas
    Its only guna raise up so much via torsions. Unless ur dropped
  7. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    My truck is only dropped by torsion in front not spindles. I wanna rais it jus to even it out from the back n so i so i wont get another ticket.
  8. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    You have to hold the nuts on top. There are 2 of them and one is a jam nut. 7/8 wrench is what you need...
  9. jetas
    So did u lower it urself?
  10. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    No i bought the truck lowerd n i dont no alot about the torsion so could some one send me a pic of the too nuts i have to hold and whats a jam nut?
  11. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    If you looking at the torsions get 2 nuts. Hold one and spin the other.
    Come my house with a 12pack and we can do um
  12. jetas
    Do a search bro. I think SDYOTA posted a how to.
  13. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    search it on where
  14. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    wea u live oahu grown cuz i live in nalo bra
  15. jetas
    On this forum.
  16. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
  17. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    Ill go and look now
  18. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
  19. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    K i got another problem Just put in a cold air intake Nd it is making a loud noise?? When i had my stock intake the nois wasnt loud only when i opend the filter box up it would be loud but now that i changed it to the cold air inake its loud because it dosnt have the plastic box to cover the noise dose any one no wat it could be?
  20. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    The "cold air intake" is going to make that noise. The sound you are hearing is the air being sucked into the motor. Its fine. Did you figure out your T bar issue?
