The Official "Other car wheels on my toyota" thread
Discussion in 'Wheels/Tires' started by SD YOTA, Feb 13, 2011.
  1. jetas
    Router and a certain cutting bit. I forgot what its called. My buddy bored out some escalade wheels for hardbody this way
  2. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    93 Toyota Pickup 2wd
    yotaman95 and twizted1 like this.
  3. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    [​IMG] [​IMG]
    I finally got around to throwing on the BBS meshies I've had sitting in a corner of the shop for months. They came off of a 1991 Lincoln Town Car. 15x6.5 +~14mm.
    Tires are 215/65R15 Sumitomos which I am very happy with so far. I know it's more sidewall than most of the cool kids here run but I'm a big fan of the late 80's sport look and I need the weight capacity for work hauling.
    Erwin Merida and Nineteen86 like this.
  4. AspireCycle
    AspireCycle Member
    Phoenix, AZ
    1978 Longbed 5 Speed
    very small difference, the lincoln wheels come in two different offsets, the mesh is flat, the star pattern in the middle is jagged. the crown vic wheels come in one offest, the mesh is "overlapped", and the star pattern in the middle has solid edges.
    Erwin Merida likes this.
  5. 1-2many
    1-2many Newbie
    These must be bored cause I Got the same set up with 205/50/17 spacers, 2"drop spindles and leaf set up bell tech shocks and I'm rubbin the front. How'd you do it
  6. DukeNewport
    DukeNewport Newbie
  7. 1-2many
    1-2many Newbie
    Sweeet! Nothing hitting/rubbing front suspension parts ex. Control arms?
  8. DukeNewport
    DukeNewport Newbie
    I don't hit or rub anything with the black truck. The white one I was on bumpstops up front and was a real bitch. It wasn't a daily... it didn't turn for shit without rubbing the fenders that were pulled and rolled like crazy.
  9. red rocket
    red rocket Newbie
    Clutch City
    93 regcab dlx
    How else would you do it besides leaving the center cap off?
  10. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    I'm not an expert, but you could run a small wheel spacer up front...just enough to clear the cap.
  11. Danica
    Danica Newbie
    Arizona
    1976 Toyota Hilux SR5 Shortbed
    What is your wheel size and offset on your black truck? And your tire size? That's an awesome looking truck!
  12. fred52
    fred52 Newbie
    Is the thread alive? Need help with some rims, 94 toy I want something direct bolt on, no modifying
  13. BatryOpratedBoy
    BatryOpratedBoy Enthusiast
    Fresno. =(
    Brave Little Toaster (Diana) and Salsa Verde (Traction Control)
    Yes and no. It will always be a good source of info but it has died off.
    But when I'm on Craigslist I typically look up Nissan 350/370, Infiniti Q, Lexus, 2nd gen Scion XB, and Ford. I tend to start vague and distill it down based on my current "market".
    Any Jeep also uses the same bolt pattern but off-road wheels tend to be heavier. It just depends on your expectations man... What are you looking for more specifically?
  14. fred52
    fred52 Newbie
    I'd just like to find some accurate info on what fits the truck, ford ranger rims don't fit, without modification, seem lots have same bolt pattern 5x114.3 it's the center bore size that doesn't match with most. Center Bore: 67.1 mm
    BRASS MONKEY likes this.
  15. fred heath
    fred heath Addict
    Raleigh, NC
    Any 5x4.5 wheel will work as long as the center hole fits the hub. Toyota wheels are “lug centric “ as opposed to “hub centric “. The center hole can be slightly larger with no effect on mounting.
  16. fred52
    fred52 Newbie
    Well I can find several 5x114.3 the center bore seems to keep being the problem, I haven't run into any with center/hub bore being larger, most I've found have to be modified to fit
  17. fred heath
    fred heath Addict
    Raleigh, NC
    Forget the 114.3. It translates to 4.5. Most Jeep wheels will fit. If you limit yourself to 114.3 you’re not going to find much selection.
    fred52 and BatryOpratedBoy like this.
  18. fred52
    fred52 Newbie
    I think where I'm running into trouble finding direct bolt on without modifying, is that I'm trying to stay 14" rims. The ford ranger rims I tried are 4.5, but center bore will not work without modifying, again 14" rims, the 15" may work, but not looking to go bigger. I'm going to do a jeep search see what comes up
  19. fred heath
    fred heath Addict
    Raleigh, NC
    Go to summit racing. You can buy 14” white wagon wheels for about $50 each. With free shipping . That’s what I’m using. 14”on the front, 15” on the rear. If you don’t want the white you can also get in chrome. I’m using the white with ABS wheel covers. They have a great selection of steel and cast wheels also.
    Erwin Merida and fred52 like this.
  20. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Aside from machining to fit, I'd imagine you could also use a wheel spacer to get around the center hub bore conflict
