Im tryin to locate the negative ignition coil and I dont know where its at on my 83 toyota pickup im trying to connect the green wire the the negative ignition coil?
Should be connected to ur dis cap center wire goes to round cylinder one of the side connections will be pos one net hook ref wire there
Yeah like he said ^ Follow your coil wire from the dizzy, Should be a - and + labeled on the coil itself [/IMG]
