tach install
Discussion in 'Interior/Electronics' started by Project80, Apr 7, 2013.
  1. Project80
    Project80 Veteran
    Granite Falls, NC
    1981 reg cab 2wd
    I am aware there is several posts on this topic, just wondering by the pics can you tell me which wire i should hook the green wire to? 20130407_170755.jpg
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    I've got mine hooked to the black wire coming out of the igniter under the coil ..not the the two wires with the clip that plugs into the coil but under those should be some wires 2 go to the green plug two go to the dizy should be one left that's the one I used
  3. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Same here. I cut back that sleve over the white and black wire and jumped into the black wire.You can test it first by wedging your green wire into the plug on the black side.
  4. Project80
    Project80 Veteran
    Granite Falls, NC
    1981 reg cab 2wd
    You referring to the green plug in with the yellow connector? Like in the pic
  5. Project80
    Project80 Veteran
    Granite Falls, NC
    1981 reg cab 2wd
    Ill take better pics of the coil and its wires
  6. Malessohomegrown
    Malesso,Guam
    no the flat plug right under your coil with your spark plug wire going to your distributer.the one with the black and white wires and a short piece of loom on it.
  7. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    green to negative side of coil
