so my brother want to get a truck and his planing on getting this...he aslo want to drop it 6-6 drop..would this work..i think this 15x8 w 0 offset i think...or should he run 15x7 w 0 offset..? Bart Wheels Stock Car Standard Weight Black Wheels 400150810-4 - SummitRacing.com
Won't be that much work. I honestly don't think you will need a pull. But I've seen 16x8 and lower offset (spacers) with not that much fender work . So your best bet will be to just try it and see if you like it or not and how much fender work you want to do honestly
i think 15x8's should work well with a different offset. plus it depends what year he gets because i think older bodystyles are a lil narrower. my 15x8's rub my back fenders all the time and i'm only at a 4inch drop.
my 15x8's dont rub at all in the rear with my 4 inch drop, but my wheels are 20mm offset in the rear with a 195/50 tire. if i put a spacer and make then to 15 or 10mm offset then i can see them kissing the fender easily. upfront i have a big enough spacer to run the wheel at about -16mm with the same size tire and no rubbing yet.
4-4 drop, 15x8, et0, 185/55/15 Front rubs the inner fender skirts while turning and going through a dip or over a bump. The bump stops in the rear are cut in half. The axle hits the frame before the tires rub. Crossmember hits the ground all the time.
oh that's cool... i run the same size tires but i guess the offset on my rims are a lil more out there. maybe i should try some 185/55 when my tires get bald again.
Yea that's what I was thinking, your offset is lower and it could be the brand of tire as some companies are a tad bigger/smaller then others.
what avout this..i think it 15x8 w a 0 offset..and run 185-60-15 Bart Wheels Economy Modified Standard Weight Black with Purple Stripe Wheels 529-5812-5 - SummitRacing.com
going with a 6/6 drop you may want to run a 50 series sidewall on that tire. 60 will be too tall and definitely will rub.
this my truck 15x8 w 0 offset with 185-60-15 w a roll fender and i never rub...and this was a 7-6 dropped..4" block and 3 inch lowering and spindal in th front w a BJ flip...
Backed oredered this Steelies from a local 4 wheel shop. What do u guys think. O and its 15x7 with 0 offset.
iThink those beadlocks would look sick on lowpros they might be a lil heavier than aluminum rims but its worth it. i don't think many people run beadlock looking rims on dropped trucks
