Steelie Swap.. what fits, bs/offset etc?
Discussion in 'Wheels/Tires' started by celica-fiend, May 2, 2010.
  1. celica-fiend
    celica-fiend Member
    Victoria, BC, Canada
    73 Hilux Longbox
    Hey all..
    The stock steelies on my truck (73/74) are in rough rough shape.. figured Id use that as an excuse to upgrade a bit.. alloys arent the look Im going for.. does anyone know of any OEM steelies in say a 15x6, 15x7 that fit a-ok on our trucks? Not planning on slamming it or anything.. so fender clearance shouldnt be an issue..
    Brett
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    if thats the case, any stock dodge truck in 2wd until about 83 should work for you. they had the same bolt pattern, a center bore large enough, and have an offset that should give a nice stance. there are many many others though as well. dodges are just easy to come by and should be fairly cheap for stock rims. or you could get some new steelies that are the d-hole or wagon wheel style and use those.
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    I have another steelie question, and i didnt want to make a thread about it....Will the stock steelie rims off a scion fit our trucks? I found a set with tires cheap, but im not sure it the hub, offset withh fit correctally with our truck. My truck is pretty low right now too so that might be an issue as well.... what ya'll think?
  4. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    im pretty sure all scions are 5x100 so the bolt pattern wont work. correct me if im wrong
  5. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Has to be 5x144.3 or 5x4.5". I think Scions are 5x100. You can do adapters but I think the bore is too small also.
  6. dillinja666
  7. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Probably worth checking out and measuring.
  8. planemos
    planemos Toyotaholic
    British Columbia
    yea 114.3 sounds right
    unless you want to make some wooden wheels
  9. dillinja666
    wat?
  10. daze752
    daze752 Member
    Oxnard CA
    well the scion tc is 5x100 but the new Xb is 5x114 and before that i think all were 4 lug
  11. standardbyker88
    lynnwood, wa
    exactly. first gen xb was 4 lug. tc was small 5, second gen xb is 5x4.5".
  12. Shifty
    Shifty Member
    Brisbane Australia
    RN16
    To confirm, yes it's definitely 5x114.3mm (or 5x4.5" for the US).
    Basically any model 5-stud hilux will have the same pettern, although you'd need to check on centre bore & offset.
  13. 74lux
    74lux Newbie
    Columbia MD
    1974 Toyota Hilux MK2
    I have a 74 Hilux and does anybody know what the offset and center bore for my truck? Thanks!
