I was running 195/60/r14 on my stocks untill i got 14x7s then jus swapped the tires, so still running 60series
Ill post one up later on today....fronts dropped till tuckin tires(about 3") and the back is stock, waiting on my blocks from streetacos... Edit: she sits pretty low up front with the 60series, plus the tires are stretched so makes it even lower.
It'll be worth it, when i got mine the rims had all red dirt stuck on um. Hit it with acid, scrubbed with a scotch brite pad and polished each one for about an hour each rim.
