will they fit on a 85 toyota pickup(base)? and if so... where?how much? and what size wheels would look right with a 2" drop front and rear?
i dont think so. hub is too small. my friend had to "enlarge" the hub hole on a set of '12 xB rims. but the bolt pattern n back spacing is ok.
damn... had a chance to pick some up for cheap, but they wont fit so the dude ebay"ed them. what size spacers would be recomended after 2"drop spirngs,and 2" lowering blocks are put in/ im going for a wide stance and a 80's mag truck look. also should i stay with the stock 15's, or move on to a larger wheel and a smaller sidewall profile?
Decided to not be lazy and google it. Google says everyone is right. Depends on the model of the car which lug pattern it has. they are all high offset so spacers are necessary, which could be a way of getting around the hub bore. Here's a link for you, also, if you don't know, our trucks are 67.1mm. LinksVvV Scion bolt pattern: Scion Lug Pattern Reference Guide LugPattern.net Hub bore source: Wheel Offset - Wheel Backspacing - Bolt Pattern - Mini Truckin' Magazine
last i checked my 80 was 8x114 but not excatly sure, id like to know if the prius wheels (black ones) would fit my 80
I'm positive our trucks are 5x114.3 for a longggggggg time. The only Scion that's not 5x100 is the xB, I believe. I'd double check first. Ashton (Predracer) 's Hilux is running wheels with 5x114.3, his is a 79 I think.
Gen2 xB are 5x114 bolt pattern....but they also have 67.1 hub bore (here is where most of us will have a problem). Lexus wheels will have the specs. The only wheels I have come across that 99% of the time will work are Nissan 350z wheels and Mustang wheels.
scion tc wheels I have some 18 inch scion tc wheels. I got the hub bored out professionally to still fit the scion center cap. brand new tires and only a couple chips in 1 rim from leaning up against something(I didn't do it). wheels fit but im too low and I cant tuck them. im 9 inches in the rear and it sits level in the front therefore I cant fit them the way I would like. 5x114.3 direct bolt up. let me know if you need them if you haven't got wheels already. 600 obo. machining was 200 and then 100 miles or so on the tires. cant beat it.
