The fuel pump seems to be in order same with all the grounds to everything ITS NOT THE AFM or the TPS the vacuum lines seem to be in decent shape any tips or ideas are greatly appreciated
spray some brake spray/carb cleaner -if it tries to run or stumbles longer than before -its fuel related. ----happened to me. spent $500 on new fuel pump and a few upgrades -found out it was a bad ecu. would be easier if u have access to noid light or a test light, try see if injectors are getting power
