Ride height
Discussion in 'Suspension/Chassis' started by Angel Mendez, Aug 2, 2017.
  1. Angel Mendez
    Angel Mendez Newbie
    Hello everybody, I recently purchased a 90 pickup that is raked. My question is, is the front lowered and the ear stock height? I'm not sure...thank for your help. 2017-08-02 19.58.39.jpg
  2. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    I can't speak for your specific truck, but my '82 had a rake to it, about 1.5-2" lower in the front. I think it was to account for load, and as it was the 80s cocaine may have been involved.
    Angel Mendez and fred.d.k like this.
  3. jetas
    seen many trucks with the ass end high up. Not sure why tho
    Angel Mendez likes this.
  4. Angel Mendez
    Angel Mendez Newbie
    Thanks for the replies. My next question is about lowering the ass end. From what I've researched, I have two options. .. leaf springs or blocks. I don't understand why there are two different options. In a car, it's just one option. ..suspension, coils or lowering springs. Why the two different type of lowering kits? Are there pros and cons to each? Thank you for your time.
  5. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Blocks are just spacers between the leaf spring and axle, lowering springs are just de-arched leaves. Blocks are easy and cheap, new springs will change geometry and you will need to get shorter length shocks. There are various opinions and theories about ride comfort for both, I'm sure some people can chime in.
    For my truck, I use 2" blocks and Belltech drop leaf springs. I found Monroe load bearing shocks with coilovers at the right length that I installed as well (the tension on the shocks' coilovers don't compress as much, so for 2" blocks with 3" drop springs, my drop is not quite 5"). I did this because I often move heavy loads, but love the low look.
  6. Justin Danger
    Bay Area Peninsula
    Drop the ass end if you want to go low, but also check your torsion keys, someone could have cranked them down to lower the frond, leaving the rear higher in comparison.
  7. Angel Mendez
    Angel Mendez Newbie
    Thanks for all the info guys.
  8. Mattyp902wd
    Mattyp902wd Newbie
    Vancouver island
    90 xcab
    I have a 90 and it came with a pretty similar rake as yours, grab a 3" block for the rear, under 50 bux, then you can fine tune your torsions to level the front out.
  9. jetas
    You planning on going low?
  10. Angel Mendez
    Angel Mendez Newbie
    I'm still on the fence with that, but I do know I want to lower the bed to level it out.
  11. Justin Danger
    Bay Area Peninsula
    hehe, that is how it starts.
  12. Justin Danger
    Bay Area Peninsula
    wheel well arches (on 84-88, not sure about later models) are at different heights, so droppin the ass makes it look like it is sagging with the reveal, so you lower the front to make the tires tuck evenly, then the rake is back, so you drop the back again, and before you know it you are laying frame.
    jetas likes this.
