Replacement Vacuum Lines
Discussion in 'Maintenance/Repair' started by Cliff Fischer, Apr 1, 2018.
  1. Cliff Fischer
    Cliff Fischer Newbie
    Arkansas
    1988 Pickup 5 speed, 2012 Tundra Platinum 4x4
    The small vacuum lines on my 22R are beginning to become brittle and I'm wanting to replace them. I would like to try and keep it close to original as possible. Does anyone know the sizes I need and a good place to pick up some?
    Thanks in advance,
    Cliff
  2. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    when I first did mine, i just went to a local auto supply store, popped the hoses off, and brought em in to get the right lengths of the right diameters.
  3. Cliff Fischer
    Arkansas
    Thanks Justin. So far I haven't had much luck at the auto parts stores for metric tubing. I will check a few more places. Also I just looked in McMaster-Carr catalog and they have some. I now to figure out the sizes I will need.
  4. fred heath
    fred heath Addict
    Raleigh, NC
    Try Amazon. You want to get silicone tubing if you can find it. It’s metric but I forget the sizes.
  5. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    I've always used auto parts tubing....1/4? Or whatever is close enough. Buy it by the foot, get like 8ft and replace one at a time, match, cut, place. Toyota rubber is the best though....most of my hoses feel brand new and they're 30+ years old.
    jetas likes this.
  6. Cliff Fischer
    Arkansas
    Thanks YOguyDA
  7. jetas
    Buy by the foot at the parts store like stated above. Cut to size and done
  8. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    If you can I'd try to keep or reuse as much of the Toyota stuff that is still good. You can just cut off stretched ends and use it to replace shorter hoses.
    Cliff Fischer likes this.
  9. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    My dad was a tuneup tech in the 70's-80's?
    He said it was routine to replace every vacuum hose every 30-40k miles on the American cars he worked on.
    To this day, he will rant and rave about his 30 year old toyota with original vacuum hoses and how Japanese rubber is amazing, lol.
  10. Cliff Fischer
    Arkansas
    Lol.
    On another note. I want to replce my work out fuse box cover decal that is located under the hood. Do you have any sources? Or should I start another thread?
  11. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Replace all the hose with silicone hoses,many sources.
    The decal goggle search it & print out & seal it & glue in place!
  12. Cliff Fischer
    Arkansas
    Thanks Truck Action. I didn' know if someone knew of a vendor who reproduced the decals.
