rearend ?
Discussion in 'Engine/Drivetrain' started by burnzya, Jun 13, 2009.
  1. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    my 79 has a 4:10 ratio in the rear. its a 7.5" 2 pinion rear. my question is- will the third member with a different ratio but still a 7.5" axle bolt in? i'm trying to get a little more speed for driving the highway out of it.
  2. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    Should aslong as it is out of a 7.5 2wd rearend i have 3.43 rearend in mine with a 4 speed i am turning about 3500 rpm @ 65
  3. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    yep.
    id be hunting the yards for a 82-85 supra.
    no 3rd to swap, but your 3rd will hold the carrier. plus its LSD.
    ya dont see to many trucks with a higher then 4.10 gears.
  4. burnzya
    bodied 73 hilux
    ok thanks!
    also nuff, i checked my other 79 that came with a w50 and it also has a 4:10. so i know i'll be fine to swap trannies. i'll have to tell my friend he's a douchebag!
  5. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    Hey Burnz if you want the best hwy speed and really sacrafice torque, so your city mpg will be ****. The 4speed truck like mine comes with a 8" 30 spline with factory 3.07 gear ratio so with your 5 speed you should turn about 1800 rpm at 65. All 4speeds from 84-88 come with this. Its probly not what you're looking for but they are cheap and plentyfull.
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    thats the 7.5 diff right?
    that is so the gearing im looking for, for my celica.
  7. burnzya
    bodied 73 hilux
    i have the stock rearend from my 86 with the 4 speed in the back yard, but its wider than the 79-83 axles.
    my 66 mustang has a 2:80 rearend, but since it's a v-8 it still got up to speed rather well.
  8. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    i think a 3.07 would be perfect for the w58. first gear is useless and 5th isnt quite high enuff with a 3.42
  9. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    My truck originally came with a 4-speed and 3:42 gears...
    I'm interested in the 7.5" 4:10 diff if you guys don't want it... PM me if you want to get rid of it....
  10. Evolmotorsports
    SCV cali
    1987 RN50 Hilux
    My 87 4speed came with a 3.07 its a 8" w/30 splines, they are all over the junk yards because 4speeds are undesirable, the carrier is specific only to the 4 speed because the pinion is so large, its about the size of both your fists put together.
  11. Evolmotorsports
    SCV cali
    1987 RN50 Hilux
    Although if you were to get a 79-83 4x4 housung with axles, the 8" carrier from the 4 speed should fit but I'm not sure if the 4x4 is wider than the 2wd in that year.
  12. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    4wd was a 6 lug. but im sure he could put something together.
    what i wonder, is i have a 78, i read its a 7" rear end. in one of my manuals i think. dunno the spline count. anything i can do to put a stronger one in? its narrow and low, so ive been at a toss up. i thought about using the 79-83 unit even though its a little wider, and putting a 4.10 lsd in if i can find one. i havent blown up the 7 inch dinko yet, but im sure i will the way i shift lol
  13. jjsjjsva
    jjsjjsva Newbie
    My 1986 2WD has a 7.5 with a 3.58 ratio and I turn 2400 at 65 mph and get 32 mpg with the 5-speed.
  14. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Bro, you bein' a necro
  15. Micro Machines
    Micro Machines Member
    Portland OR
    92 xcab 22re
    I was also thinking of swapping my 7.5 rearend with the 8" with 3.07 gears but would it be worth it? @ troll I know you said that those 8" have 30 spline axles, so will 4x4 axles with 6lugs fit in there?
  16. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Same splines, different length shafts I think. The 2wd axles always run narrower than 4wd but I think 79-85 shafts would fit into an 89-95 housing since they are both 55.5" wide.
  17. RAS671
    RAS671 Member
    Picked up 7.5" from my good friend with 4:11 gearing (open diff). 5spd. screaming at 70mph 3000 rpms. Which is really only 55mph on 15's with 50series rubber.
  18. Hilush
    Hilush Newbie
    Queensland Australia
    1979 RN41 2wd
    Any other G series diff center will bolt into it. This is a diff code identification for early Toyotas. IMG_20151116_0001.jpg
  19. jetas
