i need a rear window latch for my rear slider i have a 1992 toyota truck 2.4 please help me or can you tell me were to get one thanks in advance
Hmmm...generally you can find a generic rear window latch from your local auto parts store that will work but I'll forewarn you, it might take two tries to get the right one.
Really? That is kind of shocking but let me do some digging around this week as I myself need to replace my rear window latch since it pooped out.
If they still have any.....they don't make parts anymore for 89-95 trucks unless the parts are still in use on a new(er) vehicle. Sometimes you get lucky and they still have some left.
Catch - #69374-89103 = $10.46 - 1168 in country Lock - #69370-35010 = $28.12 - 155 in country, 168 in transit No problem getting these parts. Shawn Toyota Assistant Parts Manager
Hmmm, Interesting.....none of my local Toyota stealerships can even get me the whole window let alone the latch.
Im in Arizona. I can order them all day through my L.A. Parts Distribution Center. Let me know if your looking for anything. I can hook up forum guys with discounts.
I ordered all new ball joints last fall....was told "they are not being made anymore, you're lucky you got some of the last few". I also needed new tie-rod ends and sleeves.....was told "they are no longer available, you will have to go to after market"(which I did and had to modify the sleeves to fit my Belltech spindles). I have been building minitrucks for over 25 years....I always prefer Genuine Toyota Parts. If this is not the truth, I would like to know as they flat out said "they are no longer manufacturing parts for your 'old' truck".
Lower ball joints - #43330-39295 = $68.58 each list - 48 in country Upper ball joints - #43350-39075 = $65.74 each list - 56 in country Outer tie rod ends - #45046-39395 = $47.99 each list - 124 in country Inner tie rod ends - #45406-39155 = $71.49 each list - 116 in country Tie rod sleeves - #45465-35020 = $19.63 each list - 80 in country, 20 in transit (No problems on this stuff either)
