rear proportioning valve removal question
Discussion in 'Suspension/Chassis' started by silos92, Jun 21, 2011.
  1. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    my question is for anyone who has down this, when you remove the valve in the rearend which brake line do you use to connect to the rubber brake hose??? my brakes been sticking bad and i think the rpv might be the reason, thanks
  2. jetas
  3. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    yeah i saw this post before but i was still confused as which line to hook together, plus i never seem to have very good luck rying to use the search bar
  4. jetas
    Lol. Just guide urself by the pics. Take pics on ur phone n go out to ur truck
  5. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    You cap off the high pressure side and follow tht back an disconnect it from the rpv then connect the remaining line to the rubber hose
  6. silos92
    silos92 Member
    savannah, ga
    1992 hilux
    got, it thanks guys
  7. planemos
    planemos Toyotaholic
    British Columbia
    Woohoo full rear braking pressure lol. I remember when I had that and once I locked up the brakes to stop fast lol. It was scary but it works.
  8. IronNam
    94 XCab 22RE W58
    my toyota has the braking power to lock up from 70mph on the 205/75/14's on my steelies :D
