rear disc brake conversion
Discussion in 'Suspension/Chassis' started by 98frontier, Dec 29, 2008.
  1. 98frontier
    98frontier Newbie
    I have a 92 toyota axle that I'm dropping into my nissan. I'm looking for an afordable rear disc brake conversion... any ideas?
  2. gearmax
    gearmax Newbie
    92 .....I to would like to change to rear disc brakes!
    I have searched many web sites and found some good info. but I would like to exahust all those options before I spend any of my hard earned cash. ..I do believe that you should start with a bigger bore brake master cylinder. Any one agree? 92 22re reg cab 2wd.
  3. planemos
    planemos Toyotaholic
    British Columbia
    brakes are important
    Rear braking can be controlled by messing with the load proportioning valve. Buying a new, adjustable, valve could prove useful (Brembo?). When I lowered my Taco I removed it and plugged the tee mounted on the front frame. My brakes in the rear are at full power when braking now.
  4. 98frontier
    98frontier Newbie
    I'm looking for caliper backets and calipers that would work along with the disks that go with them...
    Has anyone done a drum to disk conversion without dropping a ton of $$$.
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I posted up what I'll be doing ,go to search ,Next Work To Be Done
    All parts are listed, a set up that will gave you a e-brake & much better braking & good looks, for around $600.
    I would recommend doing the front brake up grade posted on this site also.Again in the $600 -$700 range. I did this a while ago & it improves braking a lot!
    Will be starting my rear disk in a week or two,will post photos.:cool:
  6. Monzter Kuztomz
    Monzter Kuztomz Newbie
    Pittsburg, CA
  7. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    other than looks whats the point ? im sorry but my stock brakes stop me at high speeds no problem, even with my daytons that weigh as much as the truck lol...
    If anything abls would be nice.. im tired of sliding....
