RATE MY Trade?
Discussion in 'Pre-1975 Build-Up/Project Threads' started by YotaBastard, Mar 14, 2016.
which whay Do you think I've gone here?
Poll closed Oct 14, 2016.
  1. Classic Gain?
    100.0%
  2. Or Rubbish for Ruins;-?
    0 vote(s)
    0.0%
  1. YotaBastard
    YotaBastard Newbie
    I just Traded MY 1990 3.0 SR5 V6 with a welded diff and plenty of dents.......
    short bed, Extended Xtra Cab...with the front axle and some components for it in the bed.
    with of course A Clean title and current REG...
    drove it to trade and got towed back.
    for a 1973 Short-bed short cab.
    with of course/ALSO Current Reg and even fresher tags!
    not in "excellent condition" given...
    I got this older Pre-Smog Pickup to modify as a Camper/Motor-home or Cab-over Hauling Pickup.
    A Micro Motor-home...
    What Say YOU To THIS Trade;-?
    I gotta work on the 73 to drive it/rust in the gas.-got in the Carb?
    Straight trade/other arranged towing.
    update from the next mourning...third pic of this 73 show's the sway-bar.......it still has it's stock Sway-bar;-)
    the 1990 3.0 I traded off was missing it's front sway bar...
      File size:
      600.1 KB
      24
      File size:
      1.1 MB
      22
      File size:
      902.1 KB
      27
      File size:
      481.1 KB
      25
      File size:
      839.3 KB
      20
  2. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    The ballot is confusing, lol.
    I think you came up!
    Love the classics :)
  3. jetas
    Well from the looks of the pictures, it looks like you came up. Other truck looked like the one from top gear
    skaterat and 90DailyDriven like this.
  4. alwaysbroke
    alwaysbroke Enthusiast
    corona, cruiseifornia
    85 x cab 4seat firewall buggy, bagged 87 st cab
    73 looks good, and good thing u got rid of that 3.slow, not sure how I feel about the camper part but looks like a come up to me
  5. jdbragg
    jdbragg Enthusiast
    Acworth, GA
    Defiantly a solid trade! And i don't really care for the pre-79 trucks.
  6. YotaBastard
    YotaBastard Newbie
    Update, three days later.
    the Shifter needs a bushing/spent a few hours getting it mounted properly.
    Likely not the OEM/Stock Shifter.Fixed the Ball-popping off/out-deal/was out when I got it.
    I can now shift properly with no worry of the Shifter arm/ball coming out of it's socket...
    this 18R-C has Good to Excellent compression on all four cylinders.......
    the coil's contact's had to be sanded/coil OHM'd out fine anyway/now has good arc/Spark.
    the seats were held in with lag/deck screws.......old seat nuts were shot/had to drill/punch and bolt through the cab.
    the seats are from a car likely/drivers seat has Lumbar;-}
    frame is straight and I can find all four gears+reverse... playing with the Shifter.
    I Might hear the engine run today;-}
  7. YotaBastard
    YotaBastard Newbie
    top gear was a diesel.......and I would have wanted it/before they split the frame dropping it atop a building being blasted to the ground...I would not have parted with a Toyota diesel!!!
  8. jetas
    Im just saying it looked like it had already been in a building while tt was being demolished. Lol
  9. YotaBastard
    YotaBastard Newbie
    old Bastard just fired fine with a bit of smoke/from sitting I have no real idea how long.......
    With a bit of gas down the Carburetor of course...
    one thing after another with a pickup this old;-}
    I don't think it's fuel pump is working/or a filter is plugged.
    now to the Old-rust-in-the-tank deal.
    Do I fix it or Just buy new filters and blow it out from time to time;-?
    this stupid tank has a plug in the bottom/good for cleaning I guess.
    and getting the gas stolen.
  10. YotaBastard
    YotaBastard Newbie
    anyone know which way advances timing?
    on this 18r-c when I loosen the nut/do I turn the distributor towards the fan to advance?
    or do I turn it towards the firewall to advance?
    one thing after another/I've driven it around the block but still had to work on the Shifter.
    Shifter is likely not the original or correct.
    the bolts that were holding it to the transmission were shouldered and it was spaced to compensate for the shoulder.
    I replaced the bolts and Tapp'd it down tight with a big flat head and small hammer before torquing them down.
    lot's of play on the mounting of it...till tightened down...
    nice and solid now/the ball is far enough down in the socket that it will not pop back out again.
    and I ordered the bushing that goes on the ball./hard to find locally/ordered on Ebay.
    won't drive it much till that tiny plastic cup of a bushing comes/I ordered a pair for the sake of it.
  11. YotaBastard
    YotaBastard Newbie
    no shift ball/So I made one out of a Snooker Ball...
    had to reuse a plastic pedal from an improper gas pedal assembly/she only had the rod to throttle with.
    drove out the pin that held the pedal to the rod and J-B Welded it to the 73's throttle "rod"/up-side-down!
    looks good now anyway/can't tell it went in flipped up-side-down...the 73 had no securing-pin-hole.......
    anyone trade me a Pancake/air pan for this ash-tray?
    the tray looks to never have been used/or if it ever was is was cleaned by a Nun...
  12. YotaBastard
    YotaBastard Newbie
    used uv set clear glue/adhesive to repair a chip and an abrasion...
    drilled the chip to get the glue in with a hand vacuum pump and improvised suction cup.from an elbow of rubber pipe...
    not perfect but very sound...this adhesive repairs terrariums and set's up super quick in sunlight...
  13. YotaBastard
    YotaBastard Newbie
    Have to replace all the Balls on the Steering rack...half way there./AutoZone is the Best Place for These Part's. But I can only get my Master cylinder's at Napa? I still need an OEM/Stock 18R-c Air pan...but I put a Curt hitch on it and found a Spare 14" wheel from a 4-dr Cutlass in Pick-N-Pull... anyone close to Sacramento want to swap/trade rims/wheels? blue.jpg 1.JPG
  14. jetas
    Order from rockauto. Moog Ball joints are about $100 for all 4.
  15. Perkolator
    Perkolator Veteran
    Newcastle, CA
    75 Hilux and a 93 XCab 4wd
    I got all my steering parts from autopartsexpress. was the only place that stocked ALL the steering parts, for the best pricing of doing it all in one order. Everything was Moog brand (Reboxed Sankei "555"). Paid $225 for all 4 ball joints, all 4 tie rod ends, adjusters, idler and pitman arms, free shipping.
    Seems like your trade could be good. As much as I love my 3rd gen pickup, I think the older classics are more "valuable" since there are so many 80s/90s trucks still around.
    jetas likes this.
  16. jetas
    Damn that reminds me, im going to have to get new tie rod ends
  17. Perkolator
    Perkolator Veteran
    Newcastle, CA
    do it for peace of mind. i did everything one day except for the pitman arm because i couldn't find a socket big enough - just those parts improved the stupid sloppy steering a tad, but the pitman arm made a HUGE difference.
  18. jetas
    I noticed the boots on mine were gone when i did the balljoints. Il probably change em out when i swap out the drums for discs
  19. Frinzo
    Frinzo Toyotaholic
    Great Lakes, IL
    '86 Std Cab
    R u saying ur tie rod boots? If so, a cheaper way will be to get "universal" boots from prothane or energy suspension.. I got all new boots for all ball joints & tie rods on my truck. Will save u alot of money if your tie rods are still good.
  20. jetas
    Truck hadnt moved for years before i got it. Id rather just throw new ones on and call it a day. Peace of mind
