Power to Manual steering
Discussion in 'Suspension/Chassis' started by Nick F40, Jul 2, 2013.
  1. Nick F40
    Nick F40 Newbie
    Pa
    I know it's usually the opposite, but what all is needed to do the swap and what to look for/do? I know obviously get a manual box but is that it? just remove eveything that deals with power steering?
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I believe the center link is different so be sure to grab that too.
  3. yota89
    yota89 Enthusiast
    guam
    89 single cab
    All i did was removed the p/s pump and all that junk and then plugged up the two holes that
    The fluid goes through I have no problems turning other than my tie rods going bad...GL
  4. williyumz
    williyumz Enthusiast
    Manual rack will definitely steer better than plugged power rack, not so sure about gear boxes however
  5. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Just disconnect the hydraulic lines. I had manual on my 82, swapped it to 84+ power steer, then blew a line and been leaving it unhooked for over 3 years now.
  6. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    center link is the same. all you need is the manual box to swap and to remove all the other p/s components. you can leave the power box and just plug the lines but the manual box has a different steering gear ratio and it makes turning easier.
  7. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Does anyone know if you can get rebuild parts for the steering box?
    Specifically the gears...
    My suspension is solid! But in certain steering wheel positions I get a lot of play between the wheel and the box. I don't think I can adjust the crush anymore...
    Think the gears are worn in the box?
  8. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Yep. sounds like the gears are worn. I'm in the same boat. reman gearboxes are listed from most parts places but I don't know about actual availability. I've seen replacement gears for sale but not rebuild kits with bearings and seals.
  9. bmanning1964
    bmanning1964 Member
    Lompoc, Ca
    86 single cab swb
    So there are 2 different answers on the center link. Are they different or not ? I'm in the process of rebuilding the front suspension and steering. My center link is worn out. I have power steering and have not been able to get a definitive answer whether the center link for power steering is same as manual or not. HELP !
  10. fred heath
    fred heath Addict
    Raleigh, NC
    If you’re doing an even swap replacing only the center link go with whatever the part number is that’s assigned to your year. If there’s a difference it will show up there.
    terry r cosner likes this.
  11. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Plug it. Drive it. Tighten the adjustment screw if you have one and deal with it till it breaks! Lol it should line up, and you'll need an alignment regardless.
  12. bmanning1964
    bmanning1964 Member
    Lompoc, Ca
    86 single cab swb
    My problem is getting a correct part number
  13. bmanning1964
    bmanning1964 Member
    Lompoc, Ca
    86 single cab swb
    It has power steering . I'm trying to figure out what the exact replacement is. Sorry I left that out.
  14. fred heath
    fred heath Addict
    Raleigh, NC
    Power steering should be only the box itself, not the links or other parts.
    I don’t understand why you’re having problems unless your truck is a transition year. Worst case, take your VIN, call Toyota parts department and get the factory part number. Use that number on someplace like rock auto to get a better price. I’ve had good luck by googling the part number itself. Usually several sellers on Amazon will have it.
    Erwin Merida likes this.
  15. DN1911
    DN1911 Newbie
    This guy puts a new spin on just remove the pump and plug the lines. He takes a portion of the P/S hardline and create a short flow path for pressure and fluid from port to port on the box. Should make it easier to turn as it allows everything inside to move pressure correctly.
    could also just do a Stabfab rack and pinion conversion
