please help windshield wiper problems
Discussion in 'Maintenance/Repair' started by layedout94, Jan 30, 2011.
  1. layedout94
    layedout94 Enthusiast
    aberdeen
    94 toyota hilux
    So im having some problems.. My windsheild wipers stop in the middle of my windsheild.. If I take the arm of and correct it by puting down at the bottom of the windsheild then turn them on my wiper runs down my hood and then part way up my winsheild.. Is there a way to clock it or do something so the ending point will be at the bottom of the cycle and not in the middle?
  2. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    maybe the grooves on your windshield wiper mounts are ground down? so they are slipping in the wiper arms?
  3. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    take them off, turn your wiper on let it reset and then install it
  4. layedout94
    aberdeen
    94 toyota hilux
    Yea I already did that and it did nothing its not reseting in the right place like I said... it goes back to the middle
  5. macawilial
    macawilial Veteran
    Born and raised in San Diego
    4/4 Static dropped 81 longbed. 72 RN14 stock for now
  6. DareDevil63
    DareDevil63 Newbie
    Washington
    1993 pickup dx
    Have you checked the wiper motor? Maybe the motors going bad
  7. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    either the motor gears are stripped or the wiper mounts are stripped. Are both arms doing it exactly the same or is one acting OK? (if one's OK, it's the mount. if they're both whacked out, it's the gears and you need a new wiper motor assembly)
  8. Houa Thao
    Houa Thao Enthusiast
    Sacramento, ca
    91extracab
    I am in the middle of repairing mine. Same symton. Got a new assembly, but looks like the motor is bad too. Will swap out with my cluncker and report back on what is need.
  9. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    If you need any wiper motor parts I will be more than happy to give you mine. I don't know where you are located , but all my stuff is coming out anyway providing you pay shipping. All my stuff is in great working order. Just an option...
  10. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    Shaving them completely?
  11. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Yes sir. Smoothing out the cowl
  12. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    :waytogo:
  13. Houa Thao
    Sacramento, ca
    91extracab
    Okay. Just done swapping wiper motor and seems like motor is not bad on mine. I got a new wiper relay arm install and just need to adjust it right.
