Oil all over the bottom of Truck
Discussion in 'Maintenance/Repair' started by emvn_nvme, Apr 14, 2017.
  1. emvn_nvme
    emvn_nvme Newbie
    Honolulu, HI
    1994 Toyota Pickup
    Recently when I get off work I see a stain know the cement when I approach my truck and I look underneath the whole bottom of the engine is covered in oil. Checked under the hood it's all fine and no oil anywhere except the bottom of the engine. If anyone knows what's leaking lmk, Mahalo
  2. jetas
    Is the drain plug on tight?
    Could be the rear seal on the engine
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    LIKE SAID ,CHECK ITEMS THAT HAVE BEEN REMOVED,DRAIN PLUG,OIL FILTER
    If no signs of oil leakage there,then check engine & trans & brake oil levels to see if losing any of them!
  4. fred heath
    fred heath Addict
    Raleigh, NC
    If you have the 20R or 22R engine it may well be the front crank oil seal. This is a common fail item and can go from a small leak to a major flood.
    Clean off the area behind the crank pulley and watch for leaks with engine running. Be sure you have plenty of oil in the crankcase.
    New seals are les than $15.00
    emvn_nvme likes this.
  5. emvn_nvme
    emvn_nvme Newbie
    Honolulu, HI
    1994 Toyota Pickup
    Will do, thanks guys
  6. neonjay
    neonjay Member
    I would start cleaning those parts covered with oil and try to determine where it is coming from.
