I used the NRG slim hub with the slim QR... I had to make a custom 1/4 inch delrin spacer to make it work and also mod the horn mech in the QR as the closer u put the QR to the slim hub the steering shaft will protrude threw the center where the horn mech. Normally goes so I removed it and wired my horn to a button under the column... With a deep corn style wheel was to close to the driver i didnt like it at all...you must use a flat wheel..and if you use a normal hub or a standard QR the space issue gets worse and you have to take your hand off the wheel to signal...gets annoying.. bolted it on took it right back off I ended up just bolting my 320mm deep wheel straight to the slim hub for a perfect fitmemt for me ... I'm thinking of getting a flat wheel and going back with the QR... but yeah... hope my info helps Sorry I have no pics with the QR on the Yota Gives you an idea on spacing Bolting the wheel straight to the hub is close!!! I had to put tap between the button and steering shaft/nut to keep from setting the horn off
But I do have the slim QR on my Ghia did the same mod... here you can see the delrin and how I modded the center on the QR to basically sandwich the hole unit as one... but you loose your horn unless you run a wire like I did but its a pain in the ass to connect I just tuck it away and yell at people... but yeah learned this trick when I was in the 240 game... with deep corn wheels the adaptor needs to be slim as possible unless you have t-rex arms I've have this same QR and Nardi on like 6 diff cars so far... that's actually a momo hub for a datsun 510 I cut modified and rebroched when I no longer had the Datsun and didn't wanna drop a bill on a VW momo hub only to have to hack it up.... when in doubt make it work!! I had to bore out this hole to let the steering nut protrude
Dug threw my pics found my last yota build pics... last truck was a ext cab so I liked the space I could sit really far back.. NRG slim hum NRG slim QR delrin 1/4 inch spacer and Nardi 350mm deep corn Wasss soo clean that seat was the only blem in then int Damn I miss this truck... going threw old pics always kills me :-(
I have had sooo many bro... Datsun 510 s13 Silvia.... I miss those most ... I actually had 3 Datsun 520's all ka swapped.... 5 240sx's s13-s14 with sr20's.... ton of Vws.... pre runner trucks I've had it all!!!... Funny the cars that Nardi set up has seen... They say a threads useless without pics Did the swap myself So clean was all og when I picked it up 50k og miles and og paint!!! When I got it... I do work son My fav s13.... damn...told u it hurts... need to stop here before I cry myself to sleep... I just pray when I die and go to heaven.... ALL my cars are there
mr2 2nd gen or mk3 supra htey work i have used both take little works but they fits and cancle out your turn signales
