No #1 position on A/C-Heater switch
Discussion in 'Interior/Electronics' started by one2sho, Jun 19, 2015.
  1. one2sho
    one2sho Newbie
    Patterson, Ca.
    1987 Toyota Xtra Cab SR5
    Hello, I was wondering if anyone knows what the name of switch that controls the blower speed is actually called? Is it the fan speed switch or heater blower speed switch?? All the other positions work (II, III & IIII, execpt the I position) & also is it hard to replace it?? Thanks in advance for any HELP...
  2. MrDinkleman
    MrDinkleman Enthusiast
    SoCal
    1988 standard cab, long bed
    Huh! The #1 position on my switch burned out (a long time ago) too. I wonder if that is a common problem with these trucks. I can't really help except to say that I did buy a used replacement panel from ebay a few years ago but haven't installed it yet. I can tell swapping the panel is going to be a royal PITA because of the cables that need to be connected to the vent dampers and the heater control valve in the engine compartment. I'll check to see if the blower speed controller is easy to replace when I get home...
  3. one2sho
    one2sho Newbie
    Patterson, Ca.
    @MrDinkleman, Thanks. I think it may be a common problem, I also have seen the cables you mentioned but I hope you don't need to replace all of that.. I'll also search the web for any info on this issue.. Thanks again..
  4. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    As far as I know that switch is part of the entire heater control assembly, which isn't to awful bad to replace. I had to on my 89 4runner and it took about an hour total. I still havnt found where the last cable connects, as all cables were undone before I started..
  5. MrDinkleman
    SoCal
    Thanks, but unfortunately, I do have to replace the panel. :( The temperature control slider on the panel popped apart and the fan speed controller seems loose in the panel in my truck.
  6. SloPoke
    SloPoke Member
    corner of 33rd & go to hell
    93 standard cab dx
    For those with faulty blower switch positions....the likely cause is the blower motor resistor......they run about $15-20 at a Stealership.
    P/N for an 89 truck is
    81138-89103 (3 speed fan)
    or
    87138-89105 (4 speed fan)
    Hope this helps some of ya!
  7. one2sho
    one2sho Newbie
    Patterson, Ca.
    @SloPoke, I was just about to mention that.. I searched on google & I believe you are correct.. It doesn't seem to much of a hassle to replace either.. Thanks for the response, guy's..
  8. SloPoke
    SloPoke Member
    93 standard cab dx
    They can be a PITA to get to...located inside the firewall up behind the blower motor somewhere. Some are low and some are higher up.....not sure if it's a Japan vs USA made thing that makes them in different locations or what. I just know they are not all in the same place.
  9. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    SloPoke is correct. Check the resistor first. Very common with tacomas as well.
  10. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    It is the resistor. Mine was easy to change in my 88. Near blower under pass side compartment.
    22R88
  11. one2sho
    one2sho Newbie
    Patterson, Ca.
    Thanks everyone for the info.. Going to get started on that later today.. You guy's are a great help..
  12. one2sho
    one2sho Newbie
    Patterson, Ca.
    Update: it was the blower resistor.. A little tough to get to, but it is all good now.. Thanks for all the info..
  13. Nineteen86
    Nineteen86 Member
    Orange City Fl
    86 xcab
    Been a long time since this thread was active, but can anyone show a pic of the locations that its usually at?
  14. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Google "toyota blower motor resistor" images.
    Should give you an idea...
    Nineteen86 likes this.
