New front brakes pulstating. 96 hilux.
Discussion in 'Suspension/Chassis' started by ytk, Oct 21, 2017.
  1. ytk
    ytk Newbie
    96 Hilux
    Hi. Recently I replaced my front brakes, rotors and pads with TRW ones. Just a few 1000 kms down the road they started pulsating when brake pedal is engaged. It seems but I might be wrong that it pulsates more on light application and not so much on hard application of the pedal . I disassembled everything again, made sure the slide pins are lubed, reapplied a bit more copper paste to the metal contacts of the pads with the caliper and piston. Pads and rotors seem to be fine. It still pulsates and not sure what to check next. I think it is a PD60 type caliper . Any advice?
    Thanks!
    Ytk
  2. fred heath
    fred heath Addict
    Raleigh, NC
    Pulsating is usually caused by warped rotors. Yours are new, so that shouldn't matter unless they're warped from the factory.
    Does your truck have ABS? A malfunction in the ABS sensor could also cause pulsating.
  3. ytk
    ytk Newbie
    96 Hilux
    Thanks for the comment. No there is no ABS. My next idea is to try and swap back the old rotors to see if the new ones are the cause for the problem but it is such a messy job every time...
  4. ytk
    ytk Newbie
    96 Hilux
    warpd.jpg Is this one warped according to the photo? You can see some deforms in the inner side of the rotor , the inner lip is in an uneven thickness.
    When turned by hand there is some eneven resistance
  5. ytk
    ytk Newbie
    96 Hilux
    And according to this video (other side rotor)?
    Many thanks
  6. fred heath
    fred heath Addict
    Raleigh, NC
    That's the backing plate. Has nothing to do with rotor warp. You can't use that for a sight line.
  7. ytk
    ytk Newbie
    96 Hilux
    Im talking about the gap between the two inner lips of the rotor where the vents are. the thicknes of the material varies
  8. fred heath
    fred heath Addict
    Raleigh, NC
    Only way to know for sure it take them to a machine shop and have them checked.
