my truck is sitting about 4-6 inches off the ground in the front when all of the air is out of the bags I haven't flipped the ball joints or put drop spindles on it yet, I bought these bag brackets http://thebagshack.net//catalog/product_info.php?cPath=59_66_75&products_id=185&osCsid=3e2955aca921a9eee568c205d833762e and I used the pieces that are under the lower bag brackets and I was wandering if that could be what was holding it up so high, maybe if I took them off and put the lower bag bracket directly on the control arm it would sit lower. so far I haven't been able to get an answer because nobody knows what I'm talking about. Any thoughts on that?
I never use that thing. I put the bag plate right on the arm and make the upper mount parallel with that. You might have to trim the control arms a bit too, because they hit the mount on the lower crossmember. YOu should be able to make your truck lay no problem with all stock parts. No spindles necessary.
alright, thanks man, I appreciate it. I'll have to hit you up next time I'm in Cali. I wanna see your truck in person. it was the first thing I noticed when I stumbled upon this forum about a year ago.
anyone got pics? I have about 3/4in before my front cross member lays and I'm on 19's. I need to get that crossmember on the ground before I Z my frame right? Or will I be rocking on my tranny crossmember. Will flipping my balljoints get in on the ground?
