I would like to put a Nardi wood grain wheel in my 86, but I can't seem to find the proper adapter. I believe the bolt pattern is the same as a 6 bolt sparco hub. Any help would b apreciated.
http://www.weaksauceparts.com/store/product.php?productid=19265&cat=2324&page=1 hope this helps it says it fits 87 and up pickups so i dont know why it wont work on an 86 its also supposed to work with momo and sparco wheel patterns if not keep looking around the site they might have what u are looking for
Ok, can anyone tell me the difference between '86-'87 steering shafts? Is there a difference? and if so, what's the diff? Where's SD YOTA when you need him?
So, are they all the same from 84-up? I guess my question is will a hub adapter for an 87 work on my 84 as well?
The bolt pattern from a nardi and sparco do not match and theres no difference between an 86 and an 87 hub adapter personal and nardi make hubs that will work
A lot of 80's toyotas share the same spline count on the steering shaft. The only difference is the holes for the turn signal cancel. I have a hub from a gts corolla in my truck. All I did was drill the back of the hub for my turn signal cancel.
