My toy
Discussion in '1989-1995 Build-Up/Project Threads' started by yotaman95, Feb 11, 2012.
  1. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    Little update. They in!!!
    HiLuxDreams likes this.
  2. yotaman95
    1995 single cab
    Erwin Merida and Mikerocosms like this.
  3. yotaman95
    1995 single cab
    image.jpeg Sound proof
    Mr.Mini_4.0 likes this.
  4. yotaman95
    1995 single cab
  5. yotaman95
    1995 single cab
    image.jpeg Also picked up a ford 8.8 for what's to come
  6. 93Toyota
    93Toyota Newbie
    What's the backspace on these?
    yotaman95 likes this.
  7. EJay
    EJay Member
    Tri-Cities, Wa
    90 xcab
    AWESOME build dude. Have you noticed a road noise difference with the sound proofing? I want to replace my carpet and sound proof my floor too.
  8. KingBouyah
    KingBouyah Member
    Yotaman, Any progress on the Ford 8.8? I think my diff is about on it's last legs, so seeing this as another option intrigues me. Mine is pretty much bone stock right now, so it might be worth it to just pull a yota axle from the yard if I can hold out for one, but they're few and far between here in Ogden. I would imagine a newer Ford axle would be a bit easier to come by.
  9. yotaman95
    1995 single cab
    it's still sitting. I am going to completely rebuild the whole thing before I put it in. I am waiting on my new front brakes to come in from revolution brakes. Then I'll start working on the rear end. But there is a tech write up on here about the 8.8 it's a good read check it out!
  10. yotaman95
    1995 single cab
    Thanks pal! And yea the sound proofing is great keeps out rattle very well.
  11. yotaman95
    1995 single cab
    My wheels are 18x10.5 with a + 25mm I believe but I have 2 in. wheel adapters too.
  12. KingBouyah
    KingBouyah Member
    I think I did read through one either here or on yotatech, but I'm a little hesitant on pounding a portion of the gas tank out of the way so the drive shaft will fit. Also I wasn't clear on how to hook up the e-brake. I'll definitely do some more research on it, though. Maybe when yours is done I'll have to head down your way and take a look at it. Are you rebuilding the Ford diff yourself?
  13. yotaman95
    1995 single cab
    I will probably do it myself but I won't put it in since I am going to be putting in a 1 uz and a w58 tranny and I don't wanna shorten my drive shaft twice!
  14. yotaman95
    1995 single cab
    I pulled a leaf spring and added air shocks the ride is night and day difference! And it looks bad ass!
    Erwin Merida likes this.
  15. jetas
    Height looks good with that wheel setup
  16. yotaman95
    1995 single cab
    Thank you sir!
  17. yotaman95
    1995 single cab
    Big brakes showed up today pretty stoked to install them with the new lower control arms!
  18. yotaman95
    1995 single cab
    Does anyone know the torque spec of the LCA and the wheel stud hub to the main hub? I've looked all over and can't seem to find them. Thanks!
  19. yotaman95
    1995 single cab
    Here's a little update on the truck! New LCA's and Revolution big brake kit!
  20. yotaman95
    1995 single cab
    LCA's
    Before
    Cut brake shroud
    Caliper
    Rotor
    Finish
    Stance now!
    Erwin Merida and YOguyDA like this.
