I've searched but I haven't seen any post of what springs would work to lower my Stout? I don't want to cut my stock springs. Mighty max is not wide enough cuz the Stout spring is 5 1/4" diameter. I really don't want to spend for a custom spring. The closes spring I found close to the diameter is from a rear 91-95 mr2 springs which is 4 7/8" diameter. I haven't taking the stout springs to compare the height.
Go to the Moog website, they have a PDF file that lists all of there springs. It will have the inside/outside diameters, the spring rates, the installed/uninstalled heights, and what type of ends they have. I want to find a good match for my '73 Hilux but I don't know enough about springs to decide which ones will work the best. Here's the link: http://www.moogproblemsolver.com/moog/wp-content/uploads/2012/08/MOOG_Coil_Springs_Spec.pdf
This helps alot. I used a stock mighty max springs on my 74 hilux but i havent had a chance to drive it except around the block. I can't really give you a feedback. Thank you
