Lowering a 1975 Hilix help
Discussion in 'Suspension/Chassis' started by Corza19, Sep 2, 2015.
  1. Corza19
    Corza19 Newbie
    Lowering a 1975 Hilux help
    Hi guys, new to this site and first post as well :)
    I have an old 1975 Toyota Hilux which isn't anything special by any means, lots of rust, just ticked over 200K km's and she's a bit tired :lol:
    I've been wanting to lower it for a while now and I'm in need of some help for the front... I don't want to spend too much money on it, but I obviously need to buy some springs. I don't want it too low (still want it legal here in Australia...) but what springs do you guys use?? I thought about cutting the springs but on other forums people bite ya head for suggesting it :eek:
    I have had a bit of look on the forum but can't seem to find anything as of yet.
    Thanks guys
    -Corey
    This is an old pic so it does look a bit different now
  2. jetas
    Mighty max springs have been discussed plenty, Not sure what you call them down under. Only thing is they go really low.
    WELCOME TO TM
  3. Corza19
    Corza19 Newbie
    Thanks for the reply Jetas :)
    So I'm guessing you advise against cutting springs?
  4. jetas
    I actually just cut the springs on mine the other day(im still not driving it though)
    I just put that option out there in case you wanted a different route. Honestly though, cutting springs isnt as bad as heating them. So chop them all you want and fck what anyone says, its your truck.
  5. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Yeah... There is nothing wrong with cutting springs as long as you do it correctly.
  6. Corza19
    Corza19 Newbie
    Okay, thanks for the help guys :)
  7. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    Stock Mighty Max springs will get you down 2-2.5 inches, Dodge D50 springs will put you down 2.5-3 inches, BelTech Mighty Max springs will put you down about 4.5-5.5 inches.
  8. Corza19
    Corza19 Newbie
    Cade01, thanks for that info, I'm probably looking for a 2.5-3.5 inch drop :):)
  9. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    The D50 springs would work a treat then.
  10. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Mine had about a 3" drop total on cut springs and blocks. You have to remove your upper bump stop block on front and should cut down the bump stop in back unless you want to ride on it.
    This is the best pic I have on my phone, I think there is a side **** in my thread though.
  11. convict
    convict Member
    Brisbane, Austraila
    74 hilux (pickup)
    Welcome bud good to see a fellow Aussie here I'm not a fan of cutting springs but lowering my ute is on my list too
  12. Corza19
    Corza19 Newbie
    Been a while hahaha FINALLY down low.
    Few weeks back made some 4" lowering blocks for the rear, rolling around ass dragging for a while hah
    Over the past week my brother and I have been replacing all the steering tie rod ends and we've lowered the front. Easiest way to get springs out was to remove the LCA... ended up cutting 1.5 coils off, achieving roughly a 2" drop. All bumpstops have been removed.
    Front is slightly higher than back, but only by about 5mm. Hardly noticeable, so pretty much 650mm ground to guard all round.
    Cheers
    swiftbpm likes this.
  13. Corza19
    Corza19 Newbie
    Got the steering finished off today...., discovered it needs new lower ball joints.... :/ Job for another day.
    Looking at some 17" wheels for it next.
    twizted1 likes this.
  14. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    Lookin good!! cut another half a coil off the springs....lol.
    jetas likes this.
  15. jetas
    Yea bring the front end down an inch. Looks goofy with the back lower
  16. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    its the "cali lean" popular out here....i dont mind it at all!!
  17. jetas
    I drove like that in my old xB when it was bagged. Static just looks goofy to me lol.
  18. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    nooooo! the look is so so so SO horrible! I can't stand all those bro-trucks they look terrible. I can't believe it's actually a "look" now. I remember when I was a kid in San Diego it started with all the trucks people would install long-travel and other lift kits on the front first, then either run out of money for the rear or simply couldn't figure out how to match the front suspension - which usually involves invading the bed space for shock towers/susp. parts.
    Corza - truck looks great! I need to do the same on my truck now!
  19. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    lol...no im talkn dropped trucks look decent with a mild "lean"...not these 4 by 4 guys that lift the front a mile and roll around with the back stock, thats just retarded!! ive seen them around and i just smh like wtf!!
  20. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    got any pics of you xb?
