I have a bunch of LC Engineering Parts that I am selling for best offer I will sell stuff individually if you are interested. • 1013045 94mm Pro Stroker Crankshaft Light (Pro Journal) Knifed and crossdrilled. Lists for $950 • 1014349 94mm Pro Stroker Piston set12.0-1 compression (85-95) with 22R Head Lists for $600 • 1022018 22R/22RE 527 Circle Track / Drag Race (3000-8000 RPM Range) 527/527 lift 325 Advertised Duration 284@ .050 Lists for $200 • 1023198 22R/22RE Pro Dual Valve Spring Set Lists for $80 •1023003 22R/22RE Pro Titanium Retainers Lists for $130 •1023045 48mm Intake Valves Ferrera Stainless Lists for $70 •1023036 40mm Exhaust Valves Ferrera Stainless Lists for $70 • Cylinder Block Bored to Pro Piston Size, Cleaned, Pressure Tested, Magnafluxed with New Brass Freeze Plugs • 22R Cylinder Head Pressure Tested, Cleaned and Assembled ( Head is NOT Resized for Large Valves and Has Stock Valves/ Springs/ Retainers) Head Is A Tested Core And Ready For Machining Pics can be seen here..... https://goo.gl/photos/x39QHocjQ4JLm9787 Thanks Todd
