Laying on 20s
Discussion in 'Suspension/Chassis' started by bagger92, Apr 15, 2015.
  1. bagger92
    bagger92 Newbie
    Texas
    92 regular cab
    Trying to lay frame on some 20s? Any suggestions guys? Thanks.
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    See my thread. Laying frame is easy. Laying pinch is where it's at. Lol
    But actually. You will need drop spindles and a frame Z. A raised Trans crossmember too. Cut all your wheel well out..tub the firewall and flip the clutch master under the dash. Retaining ac will require some effort too.
  3. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    It is very doable. As mike said looke at his thread, you can look at mine but I've got a v6. Some differences but mainly the same. One of the best things to do is have the wheels and tires you plan to us so you can check clearances along the way.
  4. raylcc
    raylcc Addict
    Denver, CO
    The really simple way is to just take the wheels off completely and set them beside the truck. Then just lower the truck down to the ground. Instantly laying frame! The hard part will be getting the jack out from under the truck after its lowered. But its free! :waytogo:
    Seriously, I like the look and admire the amount of work that goes into it. Just being silly.
