Well ive been a member for a little over a year now but figure i start this build up thread and show you guys what my truck has been through i did change everything on the front end and clutch but dont have pix from those days when i first took her home put my stocks off the gs300 on her and buffed her up a bit bought crown vics from a friend for 150 for the set and started polishing she sat like this for a little over a year 3 blocks with cranked torsion up front after forgetting about her for a year i got an itxh and wanted to go lower pulled the leaf cranked the torsions more and added aor shocks out back felt the need to spend moneu so i bought a chrome front lol didnt want to do a 4runner front cause all my previous yotas had 4runner fronts decided it was time for a one piece back glass after me and a friend tinted it this was the last mod before i got a wild hair and...
in the process of doing the front going really slow tho because my wife is anout to give birth and i gotta do adult responsible stuffs my rim and tire setup is so small i might not even need to cut fender wells plus not sure but i think i need 2 inch drop spindles to completely lay the front crossmember due to the airbagit brackets im using. I just got the driver side done will keep you guys updated as more gets done
Cool dude. We're in the process of bagging my 91. I'm running 18's and put Bell Tech spindles on mine. Should help with the alignment since there is less camber! Keep us posted on your build!
