L43 to W5x swap
Discussion in 'Engine/Drivetrain' started by jetas, Mar 3, 2016.
  1. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    I finally had something useful to say lol :waytogo:
    No promises but I'll see if my old phone has some pics..
  2. jetas
    Lol. One question, is your truck a long bed? Doubt it makes a difference just thought id ask
  3. first80toyota
    Pacific Northwest
    '77 Hilux
    It was not a long bed. And I don't own it anymore, 2 big projects was too much for me.
  4. jetas
    Lol ok. Im still searching for a trans
  5. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    I think there are two sets of bolt holes in the frame for the trans cross member, I'm pretty sure I saw them while crawling around under my '73. Just check before you start cutting stuff, you may be able to just move it back to the next set.
  6. jetas
    I crawled under mine the other day and noticed the trans xmember isnt actually bolted to te bottom of the actual frame rail. There a hole on the xmember itself and one on the frame a couple inches back.
    I still have alot left to fix on this thing from what the PO did
  7. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    I guess I would have to see a picture of it, I thought they were bolted on the frame, it's been a while since I've seen my truck...
  8. jetas
    Il try to snap some tomorrow.bim going to start pulling the motor soon
  9. Sk1dmark
    Sk1dmark Enthusiast
    New Jersey, USA
    1977 Toyota Pickup, (SOLD) 1974 Hilux
    That could be the single line to describe my entire truck and build
  10. jetas
    you and me both lol.
    Sk1dmark likes this.
  11. first80toyota
    Pacific Northwest
    '77 Hilux
    In mine it was. :waytogo:
  12. jetas
    I dont think the bellhousings are compatible between the L and W series. I could be wrong
  13. first80toyota
    Pacific Northwest
    '77 Hilux
    I had a 20r originally, but it was a 22r
  14. first80toyota
    Pacific Northwest
    '77 Hilux
    Im pretty sure I used the W55 slave, but I might have reused the L43 slave. If it bolts up to it I reused it, but I think I had to modify the rod that pushes the throw out arm, either shortened or lengthened it. And throw out bearing has to be for the W55 as they are a different size. Everything else was left alone.
  15. dragoon713
    dragoon713 Newbie
    San Bernardino, CA
    1974 Hilux long bed
    Do the w5x match up with the 18r? And what clutch assembly do you need?
  16. Yotaboy
    Yotaboy Member
    If you're still looking to do this its possible. I swapped a W58 from an early Supra I beliave the celica bell housing bolts right up to the tranny. I bought the original slave for my 4 speed and shave the pin down a bit and it worked perfectly. Cut the middle of the crossmember out and moved it back a few inches to bolt the trans mount up. My old drive shaft was just about the perfect length (Long Bed) but I had to get it modified because the tranny Slip-Yoke was different. My gas milage inmproved dramatically and the length of the gears were great. I was even able to use my 20R clutch!
  17. Jeffery Newman
    Jeffery Newman Newbie
    1975 toyota hilux
    so you said you had to change the slip yoke to get your w58 to work. the reason i ask is i recently peeked under my truck and im concerned im gonna have to change out my driveline cause mine is bolted to the output of my l43 trans and my w50 trans has a slip yoke. is there any recommendations on this swap.
  18. jetas
    Post a pic
