John
Discussion in 'Maintenance/Repair' started by native56, May 20, 2012.
  1. native56
    native56 Newbie
    Yakima Washington
    1980 SR5 longbed 2Wd pickup
    I am having an over heating problem with my 1980 2 wheel drive long bed , I removed the thermostat and now I just bought a new water pump 20R Has anyone had this problem ????
  2. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    Did u check if it a leak or wat about the holes..make sure the cap it in right
  3. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    So you pulled the thermo and changed your water pump and its still over heating. Are you loosing water? Can you see it flowing when the motor is on and the cap is open?
  4. native56
    native56 Newbie
    Yakima Washington
    Thanks I can see a water leak coming from the thermostat housing every now and then , I am thinking of replacing the clutch fan . I should add one more thing I was getting water in the oil and used stop leak head gasket sealer , I bought the best one cost $60.00 the professional grade , so not sure if that would clog the water jackets in the block . It does build up a lot pressure in the radiator and if I take the radiator cap and rev the engine the water blows out of the radiator . this is what is going on need help Thanks
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Looks like your head gasket is failing that one bottle fix all stuff is just a radiator and heater core plugger flush your radiator with a strong radiator flush
  6. Diddys_89
    Diddys_89 Newbie
    definatly the head gasket
