It just never ends...
Discussion in 'Maintenance/Repair' started by 88Sandshark, Sep 12, 2009.
  1. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    ****ty man, a rebuild will run close to a new long block anywho sooooooo start saving. get around $1100 and you can get a nice new engine in there (non rebuilt head too).
  2. 22r
    22r Veteran
    Maui
    i think you should just change your headgasket and the seals, and maybe replace the timing chain assembly, and as you go just carefully inspect things for cracks or wear. like the timing cover and other gaskets. take the motor out, its not hard.
  3. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    If I keep this long enough, that OE engine is trash... will be replaced be a newer 22RE or even a carbed 22R. I don't want it completely dead... Not for at least another good 22 years...
  4. randy20r
    randy20r Member
    georgia
    1976 toyota pickup
    im with shonuff ,,, need pics
