Idle surge
Discussion in 'Engine/Drivetrain' started by LAYNLOW, Apr 22, 2017.
  1. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    93 Toyota Pickup 2wd
    Hey guys. Need some help. Been lookn online abiut this idling problem ive got on my 22re. Not all the time but when its just sutting it idles up and down fast then high then normal. Read about the idle screw. Anyone else have this problem? If so any rups in a how to fix?
  2. fred heath
    fred heath Addict
    Raleigh, NC
    Factory A/C ?
    Maybe the compressor cycling on and off?
  3. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Try cleaning the throttle body, the butterfly gets carbon buildup on the backside and sometimes won't let it close like it should.
    And while you have it off you can check the tps with a multimeter and make sure it's still functioning right.
    There's a good chance one of those is the cause
  4. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    I WISH! Haha no a/c
  5. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    Gonna try that this evening and hope thats it. Thabks for the input.
    first80toyota likes this.
  6. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    Well guys...little yota took a dump on me. She is out of commission ...BUUUT a new yota will be in the driveway saturday! so now project yota can begin!
  7. KingBouyah
    KingBouyah Member
    Man, what happened?
  8. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Seems I had this problem a long time ago & it was the IAC , idle control valve , a broken wire on the unit which I was able to repair.
    Hagan Quinto likes this.
