How To- swap in a 89-94 SR5 map light mirror
Discussion in 'Interior/Electronics' started by SD YOTA, Aug 26, 2013.
  1. USDMRN8
    USDMRN8 Newbie
    City By The Sea Long Beach, CA 562
    89' Single Cab - RN8
    THANKS so much SD Yota i was wondering this for awhile just the only thing i think you lose is the door option because the extra cabs had another light with that switch in the extra cab portion.
    But you the man you rock :headbang: :applause::waytogo:
    nevermind i see the door switch on yours not all of them have that switch
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yea, only the later models ditch that door switch option.... not sure why..?? :dunno:
  3. ITRDEC
    ITRDEC Member
    SFL
    94 Xcab
    Great write up just did mines! Can't wait to order some LEDs
    For everyone with extra cabs your splicing the black and black with white stripe wires in the drivers A pillar like SD YOTA mentioned.
  4. SD YOTA
    yes, correct, i think i forgot to mention that part...
  5. Aircooled
    Aircooled Member
    Kansas
    81 Pickup, 83 Pickup
    I love the lighting in this pic, looks awesome. Is this only with the map light? I'm unfamiliar with any of these trucks and if they have dome lights or not.
  6. IronNam
    This is with all my lights, maps and dome.
    Single cabs, little map light on mirror.
    Extra cabs, dome light in center of cab.
    SR5/ 4Runner has the dual map lights on the mirror.
    So now I have both the SR5 and regular dome light for my xcab.
    If I turned off the dome light and took that same picture in the same lighting, it'd be a tiny bit dimmer. Those LED's pack a punch.
  7. The Jewish Guy
    The Jewish Guy Veteran
    Is it possible that it can be wired so it will come on when the door opens ? and shuts off when the door closes..
  8. Aircooled
    Aircooled Member
    Kansas
    :waytogo: Thanks! I need to do this!
  9. IronNam
    The little rocker switch on the SR5 light allows that, as far as I know.
    One of the wires is actually for the door's switch.
  10. mannycabunoc
    mannycabunoc Newbie
    Friends, can somebody show how the map lights from the 4runner are removed. I was in pick n pull in Richmond last week and there are several 4runner map lights available but I don't know how to remove it. Thanks.
  11. SD YOTA
    if no one beats me tomorrow, ill take some pics on how to remove it. its pretty simple. you'll technically only need a phillips screwdriver. you pry one center cover off and then pry the main cover off and access the 4 screws to take em off.
  12. mannycabunoc
    mannycabunoc Newbie
    Sd yota, yes please share and i have a better chance of not breaking the 4runner lights when i remove it. Thanks.
  13. SD YOTA
    ok... ill get some shots of it tomorrow morning and post them here.
  14. SD YOTA
    alrighty brother here you go.
    if you dont have a set of these little toothpick tools i suggest you get em, they are one of the best set of tools ive ever bought. i use them for EVERYTHING.
    use the 90* to get into the little plastic cover here and pop it out. takes little effort.
    like so...
    next, grab the edge nearest to the windshield and pull down a bit... it may require a bit of effort since they are pressed around the edge of the housing. pull one end till it "pops"...
    then the other side... until it comes down..
    then the cover comes off and you can now remove the 4 screws that keep it in place. (pay no attention to the two missing ones on mine since its already on my truck)
  15. mannycabunoc
    mannycabunoc Newbie
    Sd yota, thanks for the instruction and immedate reply and now back to pick an pull to grab some 4runner map light....i hope they have not yet crushed the vehices
  16. SD YOTA
    for sure man. if you cant find em in the color you need, i do have one in blue and one in grey if yer interested.
  17. paseobeater
    paseobeater Member
    93 xcab
    cool to see now i need to find me a light blue mirror to match my xcab interior!
  18. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I'm gonna have to start adding these to my parts piles. Wonder how it would sit and look on an older truck. I very rarely use a dome light.
    Side topic. What is a broadway mirror? I see its larger, but is it flat or curved? I have a similar setup in my 78. It's super wide but curved. I can see all 4 corners of my truck bed and both head rests without moving my head. So wide that since I leave my visors down, it's under the driver and over the passenger one. Ill get pics tomorrow for interested parties. :D
  19. SD YOTA
    if you have an issue finding one lmk man...
    yea, the broadway mirrors come in both flat, or contoured. i like the flat ones since they look better and dont distort the distance of objects in the rear view. i have a 300mm one and think its about perfect... i see super clearly out the back and most of the sides.
    Nam i believe has a super 400mm one that is just shy of being a side to side mirror option to a "wink" or panel mirror like i had in my wagon.
  20. standardbyker88
    lynnwood, wa
    That's about what I thought. How's the interference with your visors? Mine live down since I feel I have too much cab height anyways lol. My next one is getting chopped. Any visors you've swapped to on these would be the next mod question I suppose.
