How to Identify Transmission Code
Discussion in 'Engine/Drivetrain' started by davidg1228, Jul 6, 2016.
  1. davidg1228
    davidg1228 Member
    San Jose, Ca.
    1981 Toyota Pickup Long Bed 5sp
    So, my transmission is going out. I can hear it grind through all 5 gears. I want to replace it with a used transmission. I am unsure however what transmission i current have. I did some research and found that I may have a w-50. Where can i find the identification marks on my transmission? Please help!!
    Thanks
  2. jetas
    Vin plate will tell you what came stock in your truck. I say it that way because who knows if its been swapped
  3. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    What jetas is trying to say is that toyota didn't put ID plates on the transmissions and they are interchangeable (with correct bellhousing) between pickups, celicas and supras, etc.
  4. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    So, in your case (1981) you can use a 5 speed from rwd celicas, supras and pickups from '79-95.
  5. jetas
    Thats exactly what i meant lol
  6. davidg1228
    davidg1228 Member
    San Jose, Ca.
    Thanks Guys! I looked under the hood and found that I the vin plate says I have a W50 transmission. So according to YOguyDA i can install a transmission from an 84-88 2 wd drive truck? It came off of a 22r motor. As long as it is a 5 speed too the mounting bracket is the same right?
    Thanks again!
  7. jetas
    Should be the same if its from the same gen but do yourself the favor and take the crossmember along with the trans
  8. chrlsful
    chrlsful Newbie
    Lawrence Swamp, S. Amherst. MA
    what 4 speed autos fit? Would those autos also swap onto the 2.2L diesel?
  9. fred heath
    fred heath Addict
    Raleigh, NC
    The W50 came OEM in 73-81 Celica's with the 20R. 73-81 corona's w/20R and 76-82 pickup w/20R.
    The W50 and L43 (4 speed) are both 20.8 inches long, and will fit your truck with no modifications to the driveline.
    All mid 80's W55 + are 25.5 inches long. It can be made to fit, but may require some fabrication.
    If you junk your W50, save the shifter assembly. They are unique to that transmission only. Very hard to find. May even be worth some $.
